#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 03-05-2018, 11:45 PM   #1
EMTNLSS
EMTNLSS's Avatar
Drives: 2016 Hyper Blue 2SS
New oil from Mobil 1 made for the LT1 and LT4
There was some discussion about this in another thread but figured i'd make a new post about it so more people could see it. It looks like the 2019 Corvettes are being filled with this new 0W-40 oil from the factory and it'll be the new recommended oil from now on for it. Looks like they're switching over to it for better wear protection and you'll be able to street and track with it without switching oils. I attached a PDF with all the info.
Wonder if the 2019 Camaro's will come with this oil or if GM will make this the recommended oil for them. I might switch over to it once it becomes more widely available later this year.
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune
Upcoming Mods:
EMTNLSS is offline   Reply With Quote
Old 03-06-2018, 05:51 AM   #2
SE46
SE46's Avatar
Drives: 2018 ZL1 1LE
Thanks for sharing
SE46 is offline   Reply With Quote
Old 03-06-2018, 08:33 AM   #3
sir574
sir574's Avatar
Drives: 2017 SS 1LE
Says right in the PDF its compatible for the LT1 & LT4 engines, looks like i'll be switching to this.
sir574 is offline   Reply With Quote
Old 03-06-2018, 09:48 AM   #4
jasonct
Drives: Camaro SS Nightfall Gray Metallic
Thanks for posting!
jasonct is offline   Reply With Quote
Old 03-06-2018, 11:27 AM   #5
Stocktastic
Drives: 2017 Hyper Blue SS 1LE
Also says it's the recommended oil for these engines (Corvette, Camaro & CTS-V).
Stocktastic is offline   Reply With Quote
Old 03-06-2018, 01:00 PM   #6
sir574
sir574's Avatar
Drives: 2017 SS 1LE
yes, but not the v6 or v4 trubo camaro, which is why i think it said LT1 and Lt4
Old 03-06-2018, 01:06 PM   #7
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
interesting. I wonder when it will be available.
mjk3888 is offline   Reply With Quote
Old 03-06-2018, 01:41 PM   #8
sir574
sir574's Avatar
Drives: 2017 SS 1LE
looks like Q3 2018, but it says you can get it through your chevy dealer now.
p.s. what suspension setup are you running? I like the stance you have in the pic.
Old 03-06-2018, 02:21 PM   #9
Canadian ZL1
Canadian ZL1's Avatar
Drives: 2017 ZL1, 1995 Trans Am
Thanks for sharing. I will definitely be switching to this. I like the fact it is a 40 weight plus the cold start and Wear protection caught my attention.
_____________________
'17 ZL1 HBM|A10|NAV|PDR|CFW Hood|Sunroof
Canadian ZL1 is offline   Reply With Quote
Old 03-06-2018, 02:41 PM   #10
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Nice find. Thanks for posting.
2018 ZL1 1LE sw/PDR
waterman is offline   Reply With Quote
Old 03-06-2018, 07:30 PM   #11
baron95
2018 1LE, NASA Instructor
baron95's Avatar
Drives: 2018 Camaro SS 1LE
I called my dealer - they don't have it.
Anyone talked to a dealer who can do an oil change right now with the new oil?
baron95 is offline   Reply With Quote
Old 03-06-2018, 10:02 PM   #12
Mountain
Mountain's Avatar
Drives: 2017 SS 1LE, 2016 1SS (previous)
Very cool. It looks to be a slightly more emissions friendly version of their “European” formula 0W-40, which is what I use in a lot of cars (including the Camaro, all the cars I’ve tracked and our $h!t box Lemons cars). It’s a good off-the-shelf oil. I just wish the NOVAK was published, as that’s really important to DI engines. If you run a good catch can system, not as much.
https://mobiloil.com/en/motor-oils/mobil-1/mobil-1
Mountain is offline   Reply With Quote
Old 03-07-2018, 04:49 AM   #13
sschons74
sschons74's Avatar
Drives: 16 Camaro 1SS & 82 Silverado C10
OP thanks for sharing.
Ordered 1SS Black on Black, M6 in late summer 2015.
Hurst shifter, Soler Performance ported TB.
sschons74 is offline   Reply With Quote
Old 03-08-2018, 06:35 AM   #14
DetCam
DetCam's Avatar
Drives: 2016 1SS (12/10/2016)
Of course, I just stocked up on the Valvoline Syn Power 5-40 for this coming summer. Oh well, looks like I won't switch over until fall.
This new oil sounds great. I wonder if they'll sell new Oil Caps for us to swap out under the hood to show the new recommendation.
DetCam is offline   Reply With Quote
