Old 08-14-2016, 05:58 PM   #1
rwi2112
Green Manalishi
rwi2112's Avatar
Drives: 2010 Synergy Green Camaro LT
Factory 1LE #23123398 & or JPSS ?
I'm still researching sorry if you guys are getting tired of my questions. I found on GMparts.com that I can get the factory 1LE setup for my 2010 1LT. I've talked to Justice Pete a few times and Mike @ Raymond's Performance. I like JPSS Black magic sway bars but I'm wondering if I spend the $1300 for the factory 1LE kit will I still need to go with aftermarket sway bars (and more)? If my pockets were that deep I would have bought a track ready car to begin with. I'm just wanting a little less roll on the autocross coarse. IF WE EVER HAVE ANOTHER CAMARO FEST.
Thanks Guys
rwi2112 is offline   Reply With Quote
Old 08-14-2016, 06:38 PM   #2
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
If you've already talked to Pete, then you have the straight scoop. You really need to decide what you want out of your car, and obviously what you're willing to spend to get there. I can only tell you that, as I want to fine tune my 1LE to make it even better on the track, if I was within a state or two of JPSS, I would be there in a heartbeat......kind of hard to beat that kind of knowledge base.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 08-15-2016, 12:16 AM   #3
1LeSS
1LeSS's Avatar
Drives: 2013 2SS/RS VR 1LE
Bought a 1le and went straight to JPSS to up grade the suspension and steering. Justice Peters knowledge and no bullwhip attitude lets you know you are getting the best. I'd just go to JPSS for all my upgrades
BC Racing coil-overs, 32ml rear sway bar, Solid cradle bushing kit, Steel jacket radius rod bushes, JPSS caster bolt, Bo White TB, Granitelli HP coils, Apex Catchcan, Vortech V7 Ysi Supercharger, LSX B-15 engine, custom spec cam, and other stuff.
1LeSS is offline   Reply With Quote
Old 08-15-2016, 12:25 AM   #4
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
I bought just the jpss rear sway bar and boy did it make my car feel different. I've never driven a 1/LE so I couldn't tell you how they drive but I can't imagine the sway bars are as aggressive as the JPSS black magic sway bars. The car doesn't understeer at all anymore. Definitely recommend them.
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 08-15-2016, 10:24 AM   #5
rwi2112
Green Manalishi
rwi2112's Avatar
Should I just order the individual parts out of the kit less the sway bars and then go with the Black Magic Sway bars ? I don't want to order the entire kit then throw the sway bars away to get Pete's. I'm in Indiana is why I was talking to Raymond's Performance. Raymond's said they no longer advertise JPSS, they went to a different brand but if I wanted JPSS they said they would get them for me and install them. Guess I should have looked Justice Pete up when I was in Bowling Green and actually sat down with him for a while ;-(
