JUICEDMOTORSPORTS
Old 11-17-2017, 07:21 PM   #1
B_rad1969
Drives: 2013 2lt
New gears clutch noise
I had new gears put in a couple of weeks ago. I don't think they put in friction modifier. I changed the oil and put some in. I've driven it about 100 miles since I changed it. I'm still getting clutch sounds from the rear when I turn corners and get on it a bit. How long does that friction modifier take to get in between the clutches?
B_rad1969 is offline   Reply With Quote
Old 11-17-2017, 07:52 PM   #2
wildchevy
wildchevy's Avatar
Drives: 2018 Hyper Blue 2SS convertible
go into a parking lot and do about 4 to 8 figure eights in both directions to work it into the clutches
2018 HBM 2SS CONVERTIBLE A8
wildchevy is offline   Reply With Quote
Old 11-17-2017, 08:08 PM   #3
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
what do you mean you "turn the corner and get into it"? Are you trying to get the rear to swing out? What kind of noise, chatter? If just the gears were replaced the clutch pak isn't touched. Only time I hear of this is when peeps do a clutch kit replacin the frictions and steels. And the shop should have used LS gear oil, friction modifier already in it..good luck!
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 123K! - All work by me...
Old 11-17-2017, 08:53 PM   #4
B_rad1969
Drives: 2013 2lt
It didn't do it right after I got it back. I'm guessing they didn't put it in and the regular oil got in between the clutches and started making noise. I'll do some 8's and see if that fixes it. I would have thought just driving around would take care of it. We'll see...
Old 11-17-2017, 08:54 PM   #5
B_rad1969
Drives: 2013 2lt
I put one 4oz bottle in. Just needs one, right?
Old 11-17-2017, 10:19 PM   #6
frankwjr
frankwjr's Avatar
they did put in SYNTHETIC gear oil, right? if they put in dino that could be an issue...
Old 11-18-2017, 12:47 AM   #7
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
It will go away. Just drive it.
Old 11-18-2017, 12:48 AM   #8
Bo White
Bo White's Avatar
Agreed. Synthetic has the modifier already in it too.
