10-20-2018, 11:51 PM | #1 |
Drives: 2010 ss Join Date: Oct 2015
Qa1 2 way adjustable shocks
So how well do they work for drag racings?How much front end lift?if any.I don't know if they will work for our cars.6 speed manual and 845 rwhp.thanks guys
10-20-2018, 11:52 PM | #2 |
For the front
10-25-2018, 04:54 AM | #3 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
they would be a decent set. they need to be done front and back to see the full benefit of doable adjustable coilovers for a drag application.
menscer shocks are hands down the best shocks on the market for our cars right now.
10-26-2018, 07:14 AM | #4 |
If you're going to buy a shock and or strut, buy the best.
10-26-2018, 07:16 AM | #5 |
Traction package.
10-28-2018, 07:52 PM | #6 |
^^^ You had to relocate the lower mounting hole??
10-29-2018, 08:12 AM | #7 |
Otherwise you cant adjust the rebound as the knob is buried in the LCA.
