01-02-2011, 11:02 AM | #1 |
MURC 666
Drives: 69 Pace Car 68 Camaro Restomod 81 Z Join Date: Jan 2010
LS3 LS7 head interchange
Can cyl heads be swapped between these engines ?
Guys hoarding their Camaros are depriving some youngster the opportunity to restore it 25 years from now .
Drive it like you stole it , let the next guy baby it ! |
01-02-2011, 11:12 AM | #2 | |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
Here you go.
01-02-2011, 12:16 PM | #3 |
Dog Is My Copilot
Drives: 2011 2SS/RS LS3 Join Date: Jun 2009
If you try the LS7 heads, you will also need an LS7 intake. The intake ports on the LS7 heads are different than those on the LS3. Instead of LS7 heads, I would either have the LS3 heads ported/polished or go with an aftermarket casting that's designed for the smaller bore of the LS3 (like Mast or PRC). Just my .02.
01-02-2011, 12:43 PM | #4 |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
If wouldnt spend the money on differant heads OEM or aftermarket. The LS3 heads flow GREAT. If I did anything, Id just have them ported and polished to remove some flashing, but they are great flowing heads.
01-04-2011, 07:45 PM | #5 |
MURC 666
I was wondering if LS3 heads would bolt on to the Vette 427 and I guess they do as long as you run an LS3 intake
01-04-2011, 08:31 PM | #6 | |
BAMF SS
don't see why but it is a combination that's been done.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
01-05-2011, 08:25 AM | #7 |
Drives: Camaro Join Date: Apr 2009
You will be able to run LS7 style heads on LS3 engines very shortly. I already have a LS7 configuration head going together in our new PRC castings that will have LS3 friendly valve locations! I flowed one yesterday at over 390cfm on a 4.065" LS3 bore plate!
I hope to have them dyno testing in 1-2 weeks! |
01-05-2011, 08:41 AM | #8 |
Drives: 2010 Camaro SS Join Date: Oct 2008
Nice....
01-05-2011, 09:21 AM | #9 |
You can always CNC port your LS3 heads and Keep things simple.
We have a CNC program for LS3 heads. Ted.
www.jannettyracing.com
01-05-2011, 10:03 AM | #10 |
Drives: 99 Camaro SS, 79 z28, 70 GTX Join Date: Oct 2009
Yes you can interchange heads to answer your question but the LS7 heads need a 4.125 bore and your LS3 is a 4.065 as well as the intake difference ( the intake is an easy swap over)
We have an LS3 416 we are building for someone and he is going with AI to port his heads. We usually use TEA but we are very interested to see the results from the AI heads. Then you have aftermarket solutions.. TSP posted up their newest offering and there are the MAST heads that see really good results as well. |
01-05-2011, 01:33 PM | #11 |
If you were going to go to a 416 ci what size would you CNC port the stock LS3 heads to if running forced induction at 7.5 to 8 psi boost?
01-05-2011, 01:42 PM | #12 |
BAMF SS
8
01-05-2011, 01:58 PM | #13 | |
We port differently for Boosted VS N/A. I don't know if we can quantify it in Size, because size is not a direct relation to Flow. Ted.
01-05-2011, 02:15 PM | #14 |
Sorry Ted...but now I'm totally confused...I thought high boost in FI led to blow ups in unforged LS3's/L99's?? I've read about lots of folks on here talking about blower cams being beneficial because they lower boost. Then I've also read that superchargers make their power by making boost. So adding a blower cam to a SC can cause loss of power if you don't pulley down? I need a nap and a year or two in performance auto mechanics...
Similar Threads | ||||
LS3 engine specifications | Tran | Wiki | 3 | 10-06-2010 10:56 PM |
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 | TAG UR IT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 28 | 07-30-2009 06:02 PM |
LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue | 13F20 | 5th Gen Camaro SS LS LT General Discussions | 15 | 09-22-2008 04:35 PM |
5th Gen Camaro LS3 info from Chevy Hi-Po...READ | TAG UR IT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 295 | 03-07-2008 10:06 AM |
LS3 Specs, and Descriptions | Mr. Wyndham | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 5 | 11-06-2007 01:04 PM |
