02-16-2020, 12:31 PM | #1 |
Drives: 2014 SS/RS. 6.2L V8. 6 spd manual. Join Date: Feb 2020
2014 Camaro won't start after installing front facing bumper camera
Hi all,
I'm making this post for my father, who owns a 2014 SS/RS Camaro. It has the 6.2L V8 with a 6 spd manual. He purchased a kit to install a front facing camera, and went through it step by step. However, once finished, the car won't start. He's tried to reverse through the instruction to remove it, and go back through and undo the install, but no luck. It's now been a month or more and he's had no luck with getting it to start. I don't know the finer details of the camera install, but I'm assuming there's some form of clutch safety switch that's been disconnected. Can someone give some guidance of what to look for? Things to check? What electrical switches does this Camaro have in place that would keep a manual transmission setup from starting? Thanks for any help. Last edited by MilesAway1980; 02-17-2020 at 10:39 AM. |
02-16-2020, 02:22 PM | #2 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Normally with a reverse camera you tap power from the backup lights. What kit is it? Is it a universal or integrated into the head unit?
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
02-17-2020, 10:38 AM | #3 | |
The unit is Brand Motion 5000-CA6
For what it's worth, here are the installation instructions: https://www.4wd.com/sku/Brandmotion/...d/5000-CA6.pdf I was also mistaken and it is a front facing camera, not a backup camera. I edited the original post. This is the writeup my father did: Quote:
02-17-2020, 04:03 PM | #4 | |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
I think everyone is waiting for someone else to KNOW the right answer. I don't either but will throw out a few ideas.
- We all forget some simple safety interlock things sometimes, so make sure all the boxes are checked. I don't have a manual Camaro but assume it could be Need someone sitting in the drivers seat Clutch depressed all the way Brake depressed In neutral Are any lights on, the anti theft light, looks like a key? you can google more on that fuse info Are you getting power to those related fuses? A multimeter is only $5 if you don't have one. I like to swap out for a identical part number relay or fuse when in doubt like this, a fan control or something. For more info than you wanted to know, last resort right read the instructions... Full service manual all 10,000 pages or so https://www.camaro5.com/forums/showt...php?p=10598314 Wish he hadn't taken the fuse blocks off, makes it more possible for a broken wire in the wire harness but I wouldn't stress over that until you know its not something like a ground wire left off or bad relay etc. First and foremost how many volts are you reading up front from the jumper post to engine metal part? I think should be above 12.5v, low 12s can be a problem. Turn on high beam headlights, do they shine bright? Did you try to start it with jumper cables still attached? Either at the battery or up front. Also I'd disconnect the accessory at where it was connected because simply unplugging it at the "box" won't eliminate a shorted wire in that could be causing all your problems. IDK where it tapped into but that is a good rule of thumb. Short story (pun not intended but it's there) I installed speaker wiring where twice it did the seemingly impossible and moved itself after I routed it under a cover to EXACTLY under the center of a screw hole that held the piece down, e.g. door sill so inserting the screw went thru the wire! It shorted the stereo and made you think it was a defective stereo not shorted speaker wire. I learned you must tape the wire in place so it doesn't move as you replace the carpet and covers. Last edited by silversleeper; 02-18-2020 at 09:01 AM. |
02-18-2020, 10:26 AM | #5 |
Drives: 2014 Chevrolet Camaro SS 1LE Join Date: Feb 2020
Maybe try to bypass the clutch switch? Jumper wire from one pin to the other should work.
02-18-2020, 01:03 PM | #6 |
Banned
Drives: cheby Camaro Join Date: Aug 2019
!st thing I would do is check every fuse.
