11-29-2017, 08:47 PM | #1 |
Drives: 2015 summit white Camaro Join Date: Dec 2014
Exhaust help
Okay so I’ve just received the magnaflow resonated x pipe for my 2015 v6 camaro. But im undecided on whether I should delete the mufflers or delete the mufflers and resonators as well? What about the secondary cats? Or should I save for the catless downpipes? I need opinions lol thanks
11-30-2017, 03:25 PM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
If you remove the mufflers you'll get a decent amount of drone - J-pipes will help with this. Keeping the resonators won't do much for drone but should make the tone a bit deeper, although...
I removed my resonators and mufflers and replaced with 2.5" pipe from the resonated x-pipe back and think it sounds pretty good; not sure how much the resonators would affect the sound but the sound isn't too high-pitch/raspy without them, so you could remove them as well if you wanted to. I also ended up getting j-pipes installed to help with the drone; the drone wasn't too bad for me but it can get nauseating on long drives. I wouldn't touch the cats and instead wait to replace them all together; I plan to go with Solo's high-flow cats (just waiting for the warranty to expire) as they have resonators built into them; I suspect with high-flow cats the sound will be higher/raspier and so the built-in resonators will hopefully help with this. If you're going cat-less you may want to keep the resonators, but that's just my guess.
11-30-2017, 08:09 PM | #3 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Drone and rasp are definitely personal preferences, as I know plenty of people who both do and do not like rasp and some people are really sensitive to in cabin drone whereas others enjoy it. It's all about what you want to do now vs what you are going to do later though.
If you aren't going to touch the exhaust again for a while, I'd say see about deleting the secondary cats, add the resonated x where the stock H is, and then run 2.5" pipe to the mufflers. I can't say how much in cabin noise you can handle, so I can't in good faith say yes, delete the mufflers. Watch some youtube videos with headphones. Really the only thing that changes in my response is whether you are going to get high flow cats or catless downpipes. If you are, then don't bother deleting your secondary cats. If you aren't, removing the secondaries with give a little power bump. Catless + NPP exhaust open + resonated x is still too raspy for me personally (NPP open would basically be a muffler delete) but it was fine with the stock cats and the secondary cats deleted. I'm adding a pair of Solo resonators tomorrow. When I had my Solo high flow cats (traded them to a friend) my exhaust was very smooth and quiet, easily manageable if you will. Just levels to it.
12-01-2017, 01:46 PM | #4 | |
Drives: 2014 Camaro 2LS Join Date: Nov 2015
2014 Camaro BLK 2LS, MRT 2 exhaust,CAI,Anzo projector headlights,Morimoto HID,Aftermarket fog lights,RS tail lights, Strut tower brace.
