09-16-2018, 10:23 PM | #1 |
Drives: 1980 Camaro, 1970 Chevelle Join Date: Feb 2009
Traction control?
Last week i put a pair of 315/35R20 tires on the rear of my 2010 SS. After i got them on i took it for a test drive. The first time i pulled out on the highway and started to shift thru the gears i got a reduced engine power warning and the traction light came on. I took it home and reset the code with my scanner. Drove it again and was fine that day. Next day i had it out and same issue. It will come and go now. I checked the speed with my gps and its right on the money. Think its the tires or is it just a coincidence and i have other issues?
09-16-2018, 10:59 PM | #2 |
Ponies are for girls
Put the old tires back on the car, you'll know. Problems gone, it was the tires.
H&R 1.8/1.7” drop, Overkill 80mm + intake ported by AFS, 1" insulator MACE, Accel Super Coils, THR cai, JET MAF sensor, Hurst shifter handle, GPP strut tower brace, CI ice cube tray hood vents (functional) @SemperFiCamaro
09-17-2018, 12:18 AM | #3 |
09-17-2018, 05:51 AM | #4 |
Manual or auto? Do you have a throttle controller installed?
09-17-2018, 05:55 AM | #5 |
Drives: 10 2ss/rs Join Date: Jul 2018
What does it do when you turn it off
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
09-17-2018, 05:58 AM | #6 |
376 cubic inches of fun
The rear tires have to be the same diameter as the fronts, or else traction control will continue to issue warnings.
09-17-2018, 07:10 AM | #7 |
GPI Sales Consultant
What size tires do you have up front?
Got a question about a GPI product? Feel free to shoot me a message! |
09-17-2018, 08:20 AM | #8 |
09-17-2018, 08:21 AM | #9 |
09-17-2018, 08:35 AM | #10 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
09-17-2018, 09:05 AM | #11 |
09-17-2018, 09:57 AM | #12 |
Agree - same height, shouldn't be an issue. Perhaps you damaged wiring to the speed sensor when changing the tires?
09-17-2018, 10:11 AM | #13 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
I hope you aren't running the OEM wheels with the 315 tires. That in itself could cause issues.
09-17-2018, 11:27 AM | #14 |
