02-25-2020, 09:24 AM | #1 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
Pray Performance remote tune questions
Questions for those who have had Pray Performance do a remote tune. I'm doing headers soon so I'll need to get a tune obviously. My local tuner is jerking me around so I'm considering a remote Pray tune. Brett has a solid reputation and I follow him on FB. I don't want to bother him with questions until I'm ready for the tune in April so I'll post here for advice. Brett if you're listening please chime in if you have time. I have a '16 Camaro SS M6 and not planning on racing, just spirited street use so drivability and throttle response are more important to me than HP numbers or 1/4 mile times.
1) I understand that I will need an HPT MPVI-2 handheld unit with 2 credits. Where's the best place to get one? I saw it on Amazon for $389, is there a cheaper price elsewhere? 2) What is the procedure for loading his tune and datalogging? 3) Is there software that comes with the MPVI-2 for a laptop or is it done through an app on my smartphone? 4) How has the tune worked out for you? Leaving anything on the table as compared to a dyno tune? Thanks! |
02-25-2020, 09:39 AM | #2 | |
Drives: 2018 1SS M6 Join Date: Feb 2018
1: If you go through pray you can get a package deal for the remote tune with skid mark garage. I contacted Dalton Hale on facebook to order it. Comes with HP tuner MPVI2 w/required credits, Wideband and the AEM x Series gauge which you need all of that for remote tune. 2: There are videos on youtube on how to data log and upload a tune. Its actually pretty easy. You do have to create a table in the HP Tuner program to add the wideband gauge so it reads that while you data log. 3: HP Tuner hooks up to a laptop 4: Not really leaving anything on the table except for being able to see HP/TQ numbers but even those are relative. All dynos read differently but you would be able to see actual number gains if you got a base dyno run number before adding mods/tune and using the same dyno for results. |
02-25-2020, 11:35 AM | #3 |
Drives: 2017 2SS, M6, Silver Join Date: Jun 2018
hey SSMike brett doesnt pop on the forums to much anymore he is on facebook alot more than here. He can get you squared away with everything you need, for a remote tune you will need a AEM 0334 wideband along with the HPtuners MPVI2, depending on if you have a manual or an auto you may need more than 2 credits to unlock the TCM as well. he has packages for remote tuning. feel free to hit me up through PM i chat to the mastermind himself pretty much everyday in our group chat for Pray Performance.
17 2SS, Pray Performance Forged/Stroked 416, 2.9 Whipple (Pray ported), Stage 2.5 Pray ported heads, RotoFab Big Gulp, Katech 103mm TB, Pray Performance stage 3 forced induction cam, 8.855” crank shaft lower pulley, 3.00 S/C pulley, LT4 Fueling, SMG auxiliary fuel system, 2' TSP LT headers with X-Pipe, Magnaflow Competition axleback, Mighty Mouse Wild catch can, Hurst Short Shifter. Tuned by Pray Performance. 1011WHP/982WTQ
02-25-2020, 12:39 PM | #4 | |
BL1ZZRD
02-25-2020, 12:58 PM | #5 |
yes you will. placement is at least 18 inches from the primaries. i have my bung about 2 inches above and at a ten degree angle from my factory O2 sensor. so far it has about a year of use on it and no issues from it. cost me like ten dollars to have my local exhaust shop weld it in where i wanted it.
02-26-2020, 09:43 AM | #6 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
2016 only requires 3 credits for unlocking all the controllers. ECU, TCM, FSCM. 2017+ is when things changed with E92a and T87a controllers and require more credits to unlock.
Imo No you are not leaving anything on the table. A remote tune from Brett is far better then most if not all local dyno shops. The only issue with Brett is response time because he is beyond busy. Either way I would go with him and get HPt with a AEM 0334 wideband. Actually I never even installed a wideband until I went FI. Most bolt-on setups really do not need it and his base tune is pretty much spot on with the fueling. The shift points will likely take the most work if it's a A8, but since you are M6 it shouldn't him long to dial in.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
02-26-2020, 12:09 PM | #7 |
BL1ZZRD
If I don't have to go with a wideband that would be great. I'm planning on keeping it NA so I think the wideband setup is a little more than I need, not to mention a lot of added expense!
02-26-2020, 12:10 PM | #8 | |
BL1ZZRD
02-26-2020, 12:36 PM | #9 |
Drives: 2016 Camaro 2SS Join Date: Apr 2017
Correct...for the ECU/TCM. But it's one more to unlock the FSCM.
2016 2SS, MRC, NPP, A8. Procharger P-1X,Stage II,std bypass, 3.9, Alky Meth - 10.84 @129 - DA+2000
New Mods - GPI drop ins, Kooks 2", LT4 fueling, Cam, Circle D Converter, 3.5 pulley & dual nozzle meth. |
02-26-2020, 01:11 PM | #10 |
Drives: 2001Camaro Z28 Join Date: May 2009
02-26-2020, 01:22 PM | #11 |
LARRY01Z28 the FSCM is the Fuel Sytem Control Module. when tuning it unlocks the ability to regulate and alter the fuel system, along with disable AFM for customers with exhaust changes. to give a quick example.
02-26-2020, 01:22 PM | #12 |
I would talk with pray on that one since it will be a remote tune. Will want A/F ratio to read for tuning purposes. Can always temp install it until tune is done then remove/attempt to re sell used. I am going to upgrade my gauge in a few months to show E-85 content as well as A/F since i cant find a gauge that does just E-85.
02-26-2020, 04:30 PM | #13 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
Na or fuel injected, you should get a wideband sensor. It helps failsafe the system. I bought one for my tune, and immediately unhooked it once my tune was complete. It now sits in a box in my garage in case I need another tune.
02-26-2020, 09:12 PM | #14 |
