01-13-2016, 09:49 AM | #1 |
Drives: 2012 Camaro ZL1 Join Date: Aug 2015
Dyno Tire Pressure?
Question, what tire pressure should I run on a dyno machine? I am running factor GY F1 tires right now on my car. I want to get the most accurate dyno reading with out the tires slipping. Its cold right now in Houston area and my tires will not hook up very well right now. Reason I am asking, is I had a 2014 Mustang GT with some goodies on it and the car was chirping through the gears on the dyno machine. I don't think I was getting the most accurate data with the tires chirping. Thanks
2012 Camaro ZL1 - (JRE 75 RWHP Package) - ATI Damper, 10% ATI OverDrive Pulley, RotoFab Cold Air Intake, 97 Octane Torco Tune, Mild2Wild & Nitto 555R Drag Radials, Dash Commander
01-17-2016, 06:28 AM | #2 |
Performance-Dyno.com
Drives: 2013 Camaro ZL1 Join Date: Mar 2010
We apply VHT to our dyno drum when necessary. Low tire pressures aren't preferable when doing a dyno pull to redline in fourth gear
2013 Camaro ZL1 - 10% pulley, roto-fab, tune
575 rwhp street temps, 604rwhp glory pull tuned by me at Performance-Dyno.com Last edited by jlpearl; 06-05-2016 at 04:54 PM. |
01-18-2016, 12:38 PM | #3 |
Question, why don't you do the dyno pull in 4th gear?
06-05-2016, 04:56 PM | #4 |
Good catch... this is many months late, but I just saw your reply. We do most pulls in fourth fear to capture the 1:1 ratio. This was a typo on my side.
575 rwhp street temps, 604rwhp glory pull tuned by me at Performance-Dyno.com |
