Old 05-31-2021, 10:09 AM   #1
SLY5ACE
Drives: 2013 camaro ss 1le supercharged
Oil pressure help
On full throttle i have 36psi of oil pressure. I checked oil pick up tube cleared debris checked oil pick up tube clearance from oil pan and it’s good at 1/2 inch from bottom of pan. I have copo oil pressure spring which is the highest spring you can get. I run 15w-40 racing oil from redline or rotelA 15w-40 for cruising. Not sure why my oil pressure is so low please help
SLY5ACE is offline   Reply With Quote
Old 05-31-2021, 12:16 PM   #2
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
does it fluctuate or stay at 36 psi all the time?
GPI SS1 Camshaft with vvt, GM Performance Racing lifters, Comp CAMS trunnion upgrade, TSP Chrome Molly pushrods, Pac Polished .660 valve springs, Melling 10355HV oil pump, Cold Air Inductions cai, TSP 1 7/8" longtubes with 3" exhaust, true cool 40k tranny cooler
morepowerjoe is offline   Reply With Quote
Old 06-03-2021, 09:08 AM   #3
evildead
Drives: chevrolet camaro
Did this problem appear before or after you started using this oil? If you checked the oil supply system then it may be worth changing the oil. Maybe it is worth trying another oil, for example, I have been using Shell Rotella for several years, it maintains oil pressure, there are even comparisons Mobil Delvac vs Shell Rotella Oil Comparison https://davesoilchange.com/mobil-del...shell-rotella/, you should not have any problems with the oil supply system.
evildead is offline   Reply With Quote
Old 06-03-2021, 10:11 AM   #4
Trawz
Trawz's Avatar
Drives: 2013 Camaro 1LE
How hot was the oil when it's at 36psi at WOT?
For reference, I get about 35-40psi at WOT on a hot track day with my oil temp at about 240-250 degrees.
That's with AMSOIL 5W-30.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Mishimoto Oil Cooler, BMR Tunnel Brace, Mishimoto Oil Catch Can, MSD Plug Wires, Mishimoto Radiator and Hoses.
Trawz is offline   Reply With Quote
Old 06-03-2021, 05:30 PM   #5
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
WOT has nothing to do with oil pressure, engine RPM does. Your oil pressure should be about 22-30 at idle and max out around 60 psi when the engine is at full temperature, 36 psi oil pressure maximum is not enough.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 06-07-2021, 12:01 PM   #6
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Are you running that thick ass oil because you were having an oil pressure problem already? 15w, way too thick on startup and these are designed to run 30 weight, unless you have had an engine builder build you an engine. If you aren't getiing more than 36psi throughout your rpm range and you have verified with a manual gauge you probably have some excess bearing clearances.
Greenhornet2 is offline   Reply With Quote
Old 06-07-2021, 06:11 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^exactly. These engines are designed to run on 5/30 for proper oiling and flow to all the valve train parts. It could be too thick and doesn't flow properly so the pressure will show low.
TSP STAGE 3 CAM,231/246 @112 LSA 614/641 LIFT, CIRCLE D 5C-4200-4500 CONVERTER,LOD INTAKE.CORSA EXHAUST. DSS 1 PC DS. PEGASUS SOLID CRADLE MOUNTS. 486RWTQ/475RWHP.LOTS MORE.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
