Old 06-23-2021, 06:23 AM   #1
Bigroy
Drives: 2014 camaro 2ss
Bad tune?
I just put a torqstorm supercharger on my 2014 camaro 2ss had it dyno tuned but still runs like shit any ideas
Bigroy is offline   Reply With Quote
Old 06-23-2021, 06:51 AM   #2
GAD
GAD's Avatar
Drives: Silver 2014 Camaro 2SS
I'm not going to be a subject matter expert on superchargers, but I'm going to assume more context will be needed. Lol. Expand a bit on "still runs like shit" was it running like shit before the SC? The tuner not address the issues before the tune? What exactly is it doing.
My car ran like shit last year. Turns out it had a bad ground wire to a coil pack. Doubt that's your issue but just going by your description, maybe it is.
2014 Silver 2SS L99 with Roto-Fab CAI, Kooks LT Headers, Kooks Cat-less 3” exhaust, TS Stage 3.2 VVT CAM, Circle D 3200 Stall, E85 Kit, FIC 850cc injectors and Elite Engineering Catch Can. Dynoed at 478rwhp.
GAD is offline   Reply With Quote
Old 06-23-2021, 07:22 AM   #3
gtstorey
Start with your tuner. Even if it's not his tune he should be able to see what other issues exist, (running lean, rich, misfire, knock, etc.) If he can't help you it's likely the tune and you need to find another tuner.
Old 06-23-2021, 07:48 AM   #4
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Get a new tuner, If he tuned it and gave it back to you "running like shit" that is not a tuner I would ever use again.
For anyone here to help you will have to elaborate and be very descriptive to have any sort of valid internet diagnosis. First thing I would ask is, check engine light on?
Vacuum leak would be a concern, unmetered air, something not reassembled correctly? what did the dyno numbers come out to, can you attach a copy of the sheet with torque curve. air fuel ratio boost level ect
Greenhornet2 is offline   Reply With Quote
Old 06-23-2021, 08:09 AM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^^ this for sure. Lots more info is needed to get any good feed back..
TSP STAGE 3 CAM,231/246 @112 LSA 614/641 LIFT, CIRCLE D 5C-4200-4500 CONVERTER,LOD INTAKE.CORSA EXHAUST. DSS 1 PC DS. PEGASUS SOLID CRADLE MOUNTS. 486RWTQ/475RWHP.LOTS MORE.
Old 06-23-2021, 08:17 AM   #6
Bigroy
Ok
It's basically all stock besides headers without cats and a supercharger bigger injectors it will pop and surge and go dead sometimes
Old 06-23-2021, 08:18 AM   #7
Bigroy
I got hp tuners but don't really know much about it
Old 06-23-2021, 08:20 AM   #8
Bigroy
Dyno Numbers were low I think 450hp no lights on
Old 06-23-2021, 08:29 AM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yea you need to get a new tuner!! That number is what some cammed folks WITHOUT superchargers are getting..
Old 06-23-2021, 08:30 AM   #10
Bigroy
Originally Posted by GAD View Post
I'm not going to be a subject matter expert on superchargers, but I'm going to assume more context will be needed. Lol. Expand a bit on "still runs like shit" was it running like shit before the SC? The tuner not address the issues before the tune? What exactly is it doing. No it run fine before
Old 06-23-2021, 08:31 AM   #11
Bigroy
Originally Posted by Bigroy View Post
It ran fine before
Old 06-23-2021, 11:00 AM   #12
Greenhornet2
Call Jannetty racing they can get you set up remotely as long as you know how to datalog. You'll need to be sure everything is installed correctly and no vacuum leaks fuel leaks ect.
Old 06-24-2021, 11:12 PM   #13
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Post your tune on the HP Tuners forum
FasNuf is offline   Reply With Quote
Old 06-26-2021, 12:15 AM   #14
Car Nation Videos
YouTube-Car Nation Videos
Car Nation Videos's Avatar
Drives: 2010 Chevrolet Camaro
Bro get a new tuner.
It also sounds like you have a fouled plug or damaged coil pack. Maybe even a plug wire not connected.
Keep us posted
Car Nation Videos is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
