01-19-2021, 09:44 AM | #1 |
Drives: 2017 ZL1 Join Date: Jan 2017
Struts ground, getting ready for the spring with 1LE spec Apex wheels
For the folk that have ground their struts down, does this look typical? I test fit a wheel on and there is a few mm of gap.
2017 Camaro ZL1 Coupe M6 (847whp Dynojet on 93)
01-19-2021, 04:00 PM | #2 |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
Yea that's what it looked like on mine with OEM 1LE wheels
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
01-19-2021, 05:47 PM | #3 |
TWG1
Drives: 2019 Camaro ZLE Join Date: Nov 2019
Looks about right. You don’t have to load suspension to check clearance. I found jacking it up and getting underneath from slightly behind the center of the wheel looking forward and up provided best view.
2019 ZLE M6
2019 ZL1 A10 (Sold) 1967 Jaguar XKE Series 1 Roadster 2021 F150 Powerboost (on order) |
01-19-2021, 07:31 PM | #4 |
if you have pictures I'd like to compare. I went taller than needed definitely but not sure about depth, I bought the first 1/2 or so down to the same depth as the top was.
