08-10-2020, 03:43 PM | #1 |
Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
No A/C
So, today, I drove my ZL1 to work. Roughly a 17 mile drive. Fortunately, this morning, it was only 76 degrees.
However, when I left the building, it was 96 degrees. So, I double click the unlock button and hold it so that the windows open as I am walking to the car. I hop in and fire her up, hit the Auto button on the climate control and dial it down to 70. I then proceed to exit the parking lot. It is now that I notice warm air coming out of the vents, not cold. I proceed to drive home with the windows down and park her in the garage. This was around 3pm. An hour later, I pop the hood and pull the cover off of the fuse block. I find that the A/C compressor clutch fuse is F48. A 10amp fuse. I pull it, replace it with a new one. Then fire up the engine. Still no A/C. Bummer. I will be calling the dealer tomorrow for an appointment. I just hit 17k miles. While I know I am still under warranty, I am suspicious that maybe they pinched or stretched an A/C line when they replaced the oil pump a few months back. I have not even put 1000 miles on it since the oil pump replacement. And I remember that they had to replace the A/C belt for some reason. With my luck, they will tell me that an A/C line is leaking, not their fault, and no one has one in stock. Will take weeks. That is the way my luck runs.... <sigh> Hope I am wrong on this one... Anyone else lose A/C in their ZL1 with less than 20k miles on it?
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
08-10-2020, 04:55 PM | #2 | |
Craig
Drives: 2019 ZL1 1LE Join Date: Jan 2019
08-12-2020, 10:22 AM | #3 |
Drives: 2017 ZL1 Join Date: May 2019
08-12-2020, 12:45 PM | #4 |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
08-12-2020, 12:55 PM | #5 |
Drives: ZL1-1LE Join Date: Feb 2018
AC
My AC quit 4500 miles. Took it to the dealer, it had lost the AC Belt, completly gone no lights just hot air, new belt all good.
08-13-2020, 05:26 AM | #6 | |
But, my belt is still there. When I contacted the dealer on Tuesday about an appointment, the earliest they had is Tuesday, Aug 18. So, I will let you guys know the outcome after I have it fixed.
08-13-2020, 07:23 PM | #7 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
Nah, it's not a ZL1-only feature but rather an option that has to be enabled in the infotainment settings ("Remote Window Operation"), it defaults to off.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
08-14-2020, 09:23 AM | #8 |
08-14-2020, 12:52 PM | #9 |
Craig
Like I said, you probably have a leak take it and have them do a compression test on machine at dealer
08-14-2020, 01:54 PM | #10 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
Small hole in condenser possibly - all it takes is a rock bouncing off the freeway
08-15-2020, 10:39 AM | #11 |
Drives: 2017 ZL1 Vert M6 Join Date: Feb 2019
FYI, I temporarily lost my AC on a cross-country trip during a 100+ F stretch across the Midwest on my 2017 ZL1 vert after purchasing used in NJ driving back to Cali.
I took it to a dealer for checkout - 100% clean. I hope it doesn't give out the same way in the future... when you need it the most... say driving across the Cali/Nevada/Utah desert. |
08-15-2020, 11:37 AM | #12 |
Drives: A10 ZL1 Join Date: Mar 2018
I had a leak in mine and they fixed it. Works great now
08-16-2020, 07:44 PM | #13 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
Mine went out about a year and a half from the day it was built. I was told it was leaking in a weld where one of the fill/charge ports T into the line. Been good ever since they replaced it. I probably had less than 5k miles at the time.
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
08-17-2020, 11:56 AM | #14 |
Craig
Exact same as mine, weld near the T on topside
