#Camaro6
BeckyD @ James Martin Chevy
Old 04-14-2019, 10:47 AM   #1
Rlhay2
Rlhay2's Avatar
Drives: 2017 ZL1
Heads/cam/kong ported LT4
I was a bit surprised by the results! Picking her up tomorrow. Hopefully, later this month I can get to the track to verify these results.
Kong ported blower w/2.1 upper pulley
Ported heads
103mm Throttlebody
BTR camshaft
Ls7 lifters
Kooks 2” headers
Corsa double helix mid pipe
OEM NPP suitcase muffler
Rotofab Big Gulp CAI
9.1 lower pulley
AlkyControl methanol kit
Cordes trunk reservoir
DSX low side Aux pump
DSX flex fuel sensor
AMP thermostat housing & low temp t-stat
840hp/840tq
This was 100% E85 (or as close as they could get without flushing the system). But this was out of the pump E85 and a dual nozzle meth kit.
Rlhay2 is offline   Reply With Quote
Old 04-14-2019, 11:16 AM   #2
djfury05
djfury05's Avatar
Drives: 2017 ZL1 A10
Nice results. Should probably check your oil filter for metal shavings though.
djfury05 is offline   Reply With Quote
Old 04-14-2019, 12:19 PM   #3
Rlhay2
Rlhay2's Avatar
Drives: 2017 ZL1
110% certain that I don't need to double check anything!
Old 04-14-2019, 12:54 PM   #4
regnouy37
regnouy37's Avatar
Drives: 2019 ZL1 A10
Nice! Did AMP do all of the work? I plan to drop mine off with Andy at ADM soon.
regnouy37 is offline   Reply With Quote
Old 04-14-2019, 01:24 PM   #5
Rlhay2
Rlhay2's Avatar
Drives: 2017 ZL1
Yep, I effectively dropped off a stock ZL1 and 2 months later I picked up this monster!
Old 04-14-2019, 02:51 PM   #6
Alain
Alain's Avatar
Drives: 2016 Challenger Hellcat, 2018 ZL1LE
Great numbers !!!
Where’s the oil catch can mounted ? I don’t see it.
Is the metal shavings in the oil some sort of known issue?
2016 Challenger Hellcat /B5 blue/Sepia interior/Brass Monkey Wheels/
2018 ZL1 1LE/Red hot
2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413
Alain is offline   Reply With Quote
Old 04-14-2019, 06:11 PM   #7
Zigg L1
Zigg L1's Avatar
Drives: 2018 ZL1 Garnet Red Tintcoat A10
Which catch can did you use?
I think the metal shavings they are talking about might be from the porting. But i am sure kong did a top notch job and everything was flushed and cleaned.
Zigg L1 is offline   Reply With Quote
Old 04-14-2019, 08:05 PM   #8
newchevyman
Drives: 2017 Camero ZL1
The metal shavings comment is from an incident an AMP employee had with a used car dealer that led to it going viral on social media. Is not an issue with these cars at all.
Nice numbers OP. After seeing AMPs bolt-on ZL1 run a high 9 you should see mid 9s easy with a tire.
2017 ZL1 A10
Dyno/Quarter Mile/Dragy
9.71@141.2 MPH so far.
2007 Z06 H/C/I/E Half Mile - 169 MPH. Sold.
newchevyman is offline   Reply With Quote
Old 04-14-2019, 09:18 PM   #9
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
That baby is packing the heat, great numbers and should be pretty dam fast at the track.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
laynlo15 is offline   Reply With Quote
Old 04-14-2019, 09:24 PM   #10
Markoz28
Drives: 18 ZL1 nightfall grey A10
That’s awesome! I’m considering some of the same in the future.
Markoz28 is offline   Reply With Quote
Old 04-15-2019, 02:50 AM   #11
Pepsiguru
Drives: 2018 ZL1 A10
Holy Sh*t . . . Great numbers . . .
Awesome
Pepsiguru is offline   Reply With Quote
Old 04-15-2019, 07:10 AM   #12
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
Wow!!! Great build!!!
2018 Camaro ZL1 1LE NFG; ARH 2” headers, catless mids, ARH full exhaust, Lingenfelter 18% lower pulley, ATI Harmonic Balancer, Roto-fab CAI, EE-catch can, TM ported TB, NX Lid, BMR strut tower brace. Aeroforce dual pod interceptor gauges. Tuned by Vengeance Racing!!! 644 HP @ 6250 rpm / 689 trq @ 3660 rpm
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 04-15-2019, 12:14 PM   #13
Zigg L1
Zigg L1's Avatar
Ah i see did not know that
Old 04-15-2019, 04:32 PM   #14
Rlhay2
Rlhay2's Avatar
Drives: 2017 ZL1
ECU data logs read Ethanol content was 75%.
Originally Posted by Alain View Post
Where’s the oil catch can mounted?
Opted to just reuse the OEM catch can as it drains back to the engine from the factory.
