05-21-2021, 09:20 AM | #1 |
Drives: 15 Camaro SS Join Date: Oct 2018
Dyno date set!
Hey guys. Made an appointment at the local dyno. Unfortunately not until June 5th, so a couple weeks. Guesses on what the number will be? I'm hoping for 675-700 whp
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
05-21-2021, 11:04 AM | #2 |
Drives: 2010 Camaro SS2 Join Date: Oct 2020
Mustang or dyna jet?
2010 2SS M6, Procharger, 8 rib, 12lbs, E85, Holley intake W/ fuel rails, TSP Blower cam 229/242 w/springs, Harden pushrod, FIC injectors, DSX Aux. fuel, Kooks long tube headers, xpipe, no cats, Mcleod twin disc, G Force Axles, DSS aluminum drive shaft, Detroit Trutrac, LPW dif cover w/BMR bushings, BMR Toe rods and Trailing arms, 5 Stars, M.T. E/T Streets, Hurst short throw, Mighty Mouse catch can, 702 WHP on Mustang Dyno 10.7 1/4 Mile
05-21-2021, 12:17 PM | #3 |
Dynomite. closely resembles a mustang dyno I guess
05-21-2021, 12:27 PM | #4 |
Drives: 2013 zl1 vert Join Date: Dec 2018
I’ll guess first then, 680 hp and 600 tq. My retune is set for June 4th. Hoping for 750
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
05-21-2021, 12:40 PM | #5 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
I need to see this beauty!!!
05-21-2021, 01:50 PM | #6 |
If you are ever in the Altoona or surrounding areas, hit me up!!
05-21-2021, 03:27 PM | #7 |
05-21-2021, 03:57 PM | #8 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Congrats good luck.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
05-21-2021, 04:00 PM | #9 |
Drives: 2010 SS L99 Join Date: Sep 2018
Have some birch beer for me, good luck!!!
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
05-21-2021, 04:24 PM | #10 |
Drives: 2012 Camaro SS Join Date: Dec 2019
706hp 680tq
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
05-21-2021, 05:01 PM | #11 |
05-21-2021, 05:02 PM | #12 |
Hey birch beer is pretty good haha and thank you
05-21-2021, 05:03 PM | #13 |
Nice. Hooe you hit your goal!
05-22-2021, 08:25 AM | #14 |
Been following your posts gunchamp. Your car is a beast. I think you should hit 700 rwhp. Good luck man.
