03-13-2020, 10:04 AM | #1 |
Drives: 2014 z28 Join Date: Oct 2018
NPP exhaust controller
So I wanted to be able to control the exhaust flaps, the only option is the forza controller that will hold the flaps closed on command. It’s a little pricey but does the job. So I took it upon myself to find a easier/cheaper route. Fuse tap and a 12v wireless relay, little wiring in the trunk I have full control over the flaps now, and does not appear to have any battery drain as long as the fob is in off mode after shutting vehicle down. I’d be happy to either A: possibly offer a kit to sell to forum members, or B: provide the parts used and wiring.
I didn't wanna still run wires in the cab or drill any holes, for a switch, so I used a wireless relay with a on/off fob. They way I have it wired is off= flaps open at all times ( same as fuse pulled), on= flaps closed. Could also wire it So it’s off=oem flaps control, on=flaps closed. Lmk I’d any interest here I can provide details. |
03-13-2020, 12:11 PM | #2 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
I was curious if there is a quick way to hold the flaps closed. I know you can pull the fuse to keep them open. Is there a similar manner for closure? I may run on a track that is noise sensitive (AMP in AZ.) and I'd like to have a quick trick up my sleeve just in case. Seems like you've done some good R and D in this area.
03-14-2020, 08:01 AM | #3 | |
Lover of Speed
Drives: 2018 ZLE Join Date: Feb 2016
Killer Whale Racing
2021 One Lap of America Track Videos 2019 One Lap of America Track Videos 2017 One Lap of America Track Videos 2022 Ram TRX 2018 Camaro ZL1 1LE 2020 Range Rover Sport SVR (Sold) 2014 Grand Cherokee SRT (Sold) 2014 Camaro Z/28 (Sold) |
03-14-2020, 10:40 AM | #4 |
Give speed a chance
Good to know about the AMP standard. OP appears to have a good set-up for the folks that want full control. I still have yet to pull the fuse for full attention getting, I'm pretty happy with the stock arrangement at this time.
03-14-2020, 07:37 PM | #5 |
Lover of Speed
FYI, the Forza is almost identical to what he made to include a wireless key fob. But I hear ya...enjoy and let me know if you have any questions about AMP or the exhaust controller.
Killer Whale Racing
03-15-2020, 08:43 AM | #6 | |
Arizona, if u wanted to Close the flaps quickly/easily. All you have to do is ground the blu/yel wire going to the trunk fuse/relay box. Grounding this hold valves closed. |
03-15-2020, 08:46 AM | #7 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Find someone selling an ADM NPP exhaust controller. Buy it, install it. Program it to your MyLink buttons. Done.
03-16-2020, 03:31 PM | #8 |
@MrRaZ28
03-16-2020, 03:54 PM | #9 |
03-16-2020, 06:15 PM | #10 |
Doesn't have to be this fancy...a 3 way switch is all that's needed. Cheaper too!
https://youtu.be/R1WfpAotXIY
03-16-2020, 07:02 PM | #11 | |
03-16-2020, 08:44 PM | #12 |
Sounds good, Yea the wireless is cool if you don't want to make holes. The one I had in the video that I removed, I had programmed into my Homelink like the previous post said. I just wanted a 3 way control so I did the switch. In my opinion, anyway is better than a $200 controller!
03-16-2020, 09:45 PM | #13 |
03-23-2020, 01:34 AM | #14 |
Drives: Camaro Z/28 - 2015 Join Date: Sep 2019
If I pull the refuse so that the valves are permanently open, does this have any negative effects on the motor?
I saw a youtube video where it was claimed about a Corvette with NPP exhaust that it would harm the engine. Does anyone know? |
