08-01-2018, 09:41 AM | #1 |
Drives: 2012 ZL1 Join Date: Jul 2017
Opinions on the DSX E-85 Auxiliary Kit
Hey guys. I'm thinking about pulling the trigger on E-85, specifically the DSX auxiliary pump. I've done a bunch of reading and research on it and it seems like a decent kit for the money. Has anyone done it that regrets doing it or am I pretty safe in going this route? The Squash/Fore systems are not in the budget any time soon.
~ 2012 ZL1 - DynaTech 1 7/8" Headers - ID 1050 Injectors - E85 - DSX Aux Pump -
22.5% Crank Pulley - Roto-Fab CAI w/ Big Gulp- CJ/Jannetty Tuned ~ PB ET 10.54 |
08-01-2018, 11:59 AM | #2 |
Drives: 2013 ZL1 and 2019 Ram Laramie Join Date: May 2017
It's fine if you want to limit yourself to 650-700hp. I wouldn't trust it beyond that...then you go with Squash or Fore and likely new rails.
08-01-2018, 01:12 PM | #3 | |
Drives: 2012 ZL1 Join Date: May 2017
Lots of guys go way past 650-700 myself included. I am running E85 and am at 729 rwhp and the fuel pressure is rock solid at 70psi. From my reading and talking to guys putting down way more hp than me, I would say the max is around 900-1000. Do some DD and go which ever way you feel comfortable. Better yet give Dave at DSX a call. Very smart guy and seems to be a straight shooter. |
08-01-2018, 01:20 PM | #4 | |
08-01-2018, 02:28 PM | #5 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
08-01-2018, 02:45 PM | #6 | ||
Drives: 2019 Corvette ZR1 Join Date: May 2017
The factory fuel rail is also not a significant choke of fuel supply to the injectors. I'm not sure where the misconception originated from that a 3/8" fuel rail isn't big enough, but realistically, you can put 1000+ whp on ethanol through that stock fuel rail and not run into an issue. It can handle the pressure and volume without concern. The only problem with a stock rail in my opinion is people trying to run a huge shot of nitrous and pulling the fuel off the rail. |
08-01-2018, 03:48 PM | #7 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
I run the dsx w/ 80% ethanol, id1050x, 23% lower, LTs, Cam, etc etc... fpcm edited, 70% duty cycle, 70psi ... no issues. Great system, Great tune from Dave
Even installed it myself... with the flex fuel kit |
08-01-2018, 04:14 PM | #8 |
Thanks for the input. I'm really leaning toward this kit if I do the E-85 route. I really don't think I'd go much more beyond that so my thought is that the 1050 injectors and supporting mods would be ok.
08-01-2018, 09:24 PM | #9 |
Drives: 2010 2SS/RS Join Date: Dec 2009
What is the Litre per hour flow rate for the aux fuel pump?
Orange Krush II
08-01-2018, 10:07 PM | #10 |
Drives: 2014 ZL1 Join Date: Jul 2016
Who is providing the fpcm programming now? no one i talked
to wants to do it via swap or on bench so if you are trying to do e85 as a DIY you are stuck with Fore or squash which drives the price point per hp up considerably Is it just one variable in the fpcm max fuel pressure? |
08-01-2018, 10:56 PM | #11 | |
Drives: 2009 ZR1 Join Date: May 2010
https://www.camaro5.com/forums/showp...86&postcount=3 |
08-01-2018, 11:10 PM | #12 |
I have offered it for direct purchasers, but anybody with HPT can edit it now, so I don’t really offer it because it can be a hassle.
The aux pump itself flows about 210lph at 500kPa. |
08-01-2018, 11:36 PM | #13 |
08-02-2018, 06:16 AM | #14 |
Dave did mine.
