06-10-2013, 02:59 AM | #1 |
Drives: 2010 1LT Limited Edition Camaro A6 Join Date: Aug 2011
100 or 159?
Been doing ALOT of thinking, and I think I figured out what I want to do.
I was either going to: a) Trade my 6 for an 8 b) supercharge or c) Nothing I couldnt do A) because I loveeee the color of my synergy green camaro and there were no 8's in green in my province. I can't afford supercharge and to tell you the truth I really don't "Race" that much. So I decided to do nothing... THAT IS.... until I remembered there is a beautiful thing called Nitrous. I seriously think Nitrous is the answer I am looking for! That being said, Should I run 100 or 150? I am wanting the most power, but I don't want to run 150 if my car will go KABOOM! My setup consist of the following: BBK long tube headers/hi flow cats. MRT 1 CAI intake Stage 4 ported intake manifold Intake Manifold spacer Plenum spacer Ported Throttle body. If I ran 150 would I need to look at upgrading more things in my car??? That car is an automatic. |
06-10-2013, 03:07 AM | #2 |
Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
I would do 125 at most if you can't afford for something to go boom. I do recommend staying at 100 if you aren't racing for money or something.
06-10-2013, 03:30 AM | #3 | |
What kits provide 125? I wouldn't mind getting a kit that can do 150 aswell JUST incase I DO decide to run 150. |
06-10-2013, 03:59 AM | #4 |
Pretty much all the kits do up to 150. ZEX, Nitrous Outlet, NY-Trex
06-10-2013, 05:58 AM | #5 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Look into a progressive controller if u run a bigger shot. It will help soften the hit to the suspension and help with wheel spin. I run one one my 67 so initial hit off the line is 20%.
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
06-10-2013, 06:25 AM | #6 |
06-10-2013, 07:36 AM | #7 |
Yes, not as big of a shock to engine and suspension at once. The progressive controller is adjustable for what ever % u want.
06-10-2013, 07:51 AM | #8 |
Drives: Really Slow Join Date: Apr 2010
don't think you need a progressive controller with 150shot or smaller. if you got more than 150, then I would look at progressive. That's IMO. would recommend a window switch so you don't start spraying until at least 3k rpm.
06-10-2013, 07:56 AM | #9 |
depends if wheel spin is an issue...i am only running 100shot on my BBC but lots of wheel spin so i set it at 20% off the line
06-10-2013, 08:08 AM | #10 |
yeah, people use nitrous in different ways I guess. I never spray off the line, so don't have issues with traction.
06-10-2013, 08:34 AM | #11 |
I am so tempted to run a 75 shot on mine...waiting for a good deal..seen the Ny-Trex kit for $777.
06-10-2013, 08:51 AM | #12 |
Drives: 2012 Camaro 2LT RS Join Date: Mar 2012
I run the Ny-trex Triple Treat system at 100HP level and have great results. I gained a second in ET and 7mph. That was on a open diff with P/zero tires. I spray at 3500 in first gear. I use a full manual control system that works off a button I control when to spray. I could not spray from the line without major traction problems. <---- With the open diff and stock tires. I have over 150 runs at the 100HP level. Make sure whatever system you use to have some basic safety backups in place. Low fuel pressure cut-off, bottle pressure gauge, etc.
06-10-2013, 09:35 AM | #13 | |
This is DEFINITELY the answer I am looking for. Screw getting the v8... Im gonna made my 6 total badassssss! :P |
06-10-2013, 09:41 AM | #14 |
Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
Just take it slow and do it right. Look at the FI list and see all the folks running nitrous and read about their experiences. Hit up vendors and get their opinons. Basically, learn from what others have already done.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
