07-30-2018, 10:14 AM | #1 |
Drives: 2017 Camaro 2LT RS 3.6L Join Date: Mar 2016
What is this?
Hi guys, I’m hoping you all can help. The lady friends 2016 Mustang (yes I know it’s a mustang but I need help lol) has this ugly thing show...I have no idea what it is, nor what to do to get rid of it. It’s almosy like a run mark, and when you run your finger across it has a weird feeling to it.
I’ve tried: claying, ultimate Polish with white and orange pads...won’t go away. It’s hard to get on camera or even see but still. Is this anything serious? I’ve tried googling and that was useless. |
07-30-2018, 10:51 AM | #2 |
Drives: 1968 SS/RS, 2006 H2 2016 2SS White Join Date: Sep 2015
Have you tried gasoline and a match?
2016 2SS White fully loaded
07-30-2018, 10:59 AM | #3 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
Alcohol
Aceton Glas cleaner Ask a pro car dedailer
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
07-30-2018, 11:06 AM | #4 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
Run your fingernail over it, can you feel it? if not use IPA and see if that removes it. You used polish, try something more aggressive? Try wet sanding? If you're not comfortable wet sanding find someone who is.
07-30-2018, 11:24 AM | #5 |
07-30-2018, 11:25 AM | #6 |
07-30-2018, 11:26 AM | #7 |
You can feel it. And I can try IPA, wet sanding not the most comfortable! I’m not sure what the heck it is.
07-30-2018, 12:41 PM | #8 |
this could also be a factory defect that was touched up at the factory and nothing can be done except respray. I have one on my car that only the best eye will catch.
07-30-2018, 01:14 PM | #9 |
#TeamBeckyD
Drives: 2017 HBM 2SS Convertible A8 Join Date: Aug 2008
looks like it's under the clear
#TeamBeckyD
**FIFTY HBM 2SS VERT** |
07-30-2018, 01:29 PM | #10 |
07-30-2018, 01:31 PM | #11 |
I thought too, you can feel it. Her car is solid too, except the door had to get replaced because the seal broke lose and was holding water in the door...
07-30-2018, 02:14 PM | #12 | |
#TeamBeckyD
Ok maybe a tape line of some sort but if ditching is removing it rated odd Sent from my iPhone using Tapatalk
#TeamBeckyD
07-30-2018, 02:41 PM | #13 |
07-30-2018, 03:14 PM | #14 |
#TeamBeckyD
very well could be after looking at the rust on the door. I would have the dealership look at it I know most times they are useless.
#TeamBeckyD
