12-03-2018, 09:24 AM | #1 |
Drives: 204 Join Date: Nov 2018
Zl1 suspension 100kmi alternatives
Hi all,
My 2014 Zl1 has 100kmi on it and the mag ride has all but leaked out, all are black leakey bled out and I am riding on springs at this point. Car is a Daily Driver and with the mileage and value of the vehicle I am looking at alternatives to suspension replacement. So with the Budget in min I CANNOT spend 450 a corner for mag ride that will prob blow out again in 40kmi. SO does anyone know where I can find used mag ride shocks/struts OR if the 1LE / FE6 shocks / struts would work inside our springs etc. I know the Mag ride wont work, but at this point I would be happy spending 600$ to make the car drivable and comfy than 2000+ for the magride. What else would I need to do to disable the Mag Ride ? Thanks for your help guys What do you all think ? |
12-03-2018, 09:31 AM | #2 |
Drives: 2013 VR ZL1, M6 Join Date: Nov 2017
You don't have to spend $450 a corner...
Check E-bay for lightly used (fully assembled) mag shocks/struts. I had to replace my drivers side front strut due to it leaking and riding rough... Purchased a super low mile strut assembly (1.5k miles) for $150 shipped, and was on my way to like new ride and handling. I would personally stick with the mag ride. The adjustability for normal driving and track is such a nice feature.
#3257 | 485whp 526wtq | K&N 63-3079 | Gates K080660HD (Green Belt) | ACDelco UPF48R | ZL1 Addons Wicker Bill | Mild2Wild
12-03-2018, 12:16 PM | #3 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
Buy OEM new... As of April 1st Delco offer's lifetime replacement on these Mag Struts purchased from GM Dealer, RockAuto, Amazon etc. I cant stand RockAuto because you cant talk with anyone live, and at the time I got them during the summer Summit was still working things out with Delco. I know because my rears failed again after 500 miles and Amazon replaced both rears NC. |
12-03-2018, 01:26 PM | #4 |
OEM new is like 500 x 4 that's 2k$...
as an alternative could I drop the 1le struts into the zl1 springs and call it a day without mag ride... used is a great suggestion, but how long will they last...Dice roll |
12-03-2018, 02:12 PM | #5 | |
Yep the forum has taken on a whole new light now that we are in to 2nd, 3rd,and 4th owners. if you are patient you can find deals; Amazon You ordered 1 of ACDelco 580-429 GM Original Equipment Front Passenger Side Suspension Strut Assembly Kit Total Before Tax: Estimated Tax: Order Total: $162.19 $9.73 $171.92 You ordered 2 of "ACDelco 580-445 GM Original...". Total Before Tax: Estimated Tax: Order Total: $681.58 $40.90 $722.48 |
12-03-2018, 03:24 PM | #6 |
Drives: 2013 ZL1 Join Date: Dec 2015
Why not go to coil overs? Has to be someway to turn that mag ride off? Are we to be controlled by computers?
12-04-2018, 02:37 AM | #7 |
Those who need me got me
Drives: 2022 ZL1 A10 Join Date: Aug 2017
Seems wrong to remove the mag ride from a ZL1. With the accelerating cornering and braking ability of a ZL1, I would be cautious about removing the mag ride.
12-04-2018, 10:27 AM | #8 | |
Like the z28, 1le just to throw out there. |
12-04-2018, 11:21 AM | #9 |
Instagram: Sangstah
I would just go to some quality coilover setup.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
12-04-2018, 02:30 PM | #10 |
Drives: 2013 ZL1 M6 Join Date: Sep 2016
I was thinking going coil overs because i am pretty sure my front shocks are dead.
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP 630.35 RWTQ |
12-04-2018, 04:37 PM | #11 | |
2013 Camaro ZL1 M6: Rotofab CAI, JDP ZL-R Rough Idle Cam, Upgraded Valve Springs and Pushrods, Ron Davis Heat Exchanger, Alky Methanol Injection, Rx Catch Can, 87mm VMAX Ported TB, Summit Performance Spark Plug Wires, 10" Lower Pulley, Kooks 1 7/8" Headers with Magnaflow Cats, ID850 Injectors, Johnson 2110R lifters, EBC Slotted Rotors+Hawk Pads, Rotofab SC Coolant Reservoir, 160* Thermostat, Custom Mild to Wild switch, Tune, 1st to 4th bypass. 685 RWHP / 640 RWTQ.
12-04-2018, 08:32 PM | #12 | |
If you read my post you would know they don’t last any longer as I noted my two rears failed after 500 miles ( I blame Ted Jannety for too much horse power). If you search other forums like Cadillac and other GM vehicles the mag strut has a horrible reliability record. The ones I have now don’t have as much gas charge as the ones I replaced which matched the original struts. You can easily check the failure of the rears, you shouldn’t be able to open the trunk and press bounce the rear with a functioning strut. |
