09-19-2018, 10:49 PM | #1 |
Drives: 2015 Camaro Z/28 Join Date: Jul 2018
Trunk items
Do I need to keep any of this stuff ?
09-20-2018, 05:54 AM | #2 |
Drives: 2015 Z/28, 2007 HHR Join Date: Jan 2014
The yellow spring spacers might come in handy some day..
09-20-2018, 07:15 AM | #3 |
Drives: 14' Red Z/28 #336 Join Date: Mar 2016
The rubber washers on the cardboard are for the deck lid if you have a wicker bill installed
09-20-2018, 07:17 AM | #4 |
Drives: 2015 Z/28 #0058 Join Date: Apr 2018
Whats the brackets and all the loose hardware for?
Current:
- '15 Z/28 #0058 | White | A/C | Speakers | Michelin PS4S 305/30/19's - '22 Ridgeline RTL | White | Ebony, '22 CR-V EX-L Hybrid | White | Ebony Sold: - '15 Z/28 #0048 | White | A/C | Speakers | Michelin PS4S 305/30/19's https://www.instagram.com/__jon__athan__/ |
09-20-2018, 11:16 AM | #5 |
Anything of high importance I should keep?
09-20-2018, 06:26 PM | #6 |
Drives: 2015 Z/28 #397 2022 ZL1 #1799 Join Date: Jul 2009
Keep the wheel locks and the key!
09-20-2018, 06:36 PM | #7 |
Drives: 2015 Z/28; 1969 Camaro SS Join Date: Nov 2015
If the parts came off that car you keep them with the car. Just my opinion.
09-26-2018, 10:02 PM | #8 |
Drives: 2015 Z/28 #786 Join Date: Mar 2013
The yellow spring spacers should be kept with the car. They will raise the splitter about 1 to 1.5" when installed in the front springs. They are for loading on a trailer and my be needed if loading on a rollback tow truck.
I don't believe there was a factory wheel lock option so the locks in the picture may not fit your wheels. Mine didn't come with wheel locks.
2015 Z/28 #786 - Black
2004 Silverado 3500 Dually - D'Max - Suncoast - Banks - Edge - Custom Tune by D'Max Tuner / Spitzer '32 Bantam Altered Drag Car - Blown Alcohol 380 CI Small Block Chevy |
09-28-2018, 07:40 PM | #9 | |
Drives: 2015 Z-28 white Join Date: Dec 2015
1969: Bought new Z-28
2015: Bought new Z-28 Selected rides from past to present: Brabham BT-18 F-3/C ('70) Chevron B-17 F-3/C ('71) 911S/T 2.3 liter IMSA ('72) The one that got away March 73B F-Atlantic ('73-74) 944S2 '89 SP-3, Super Cup (2007-'11) Boxster S 2000, F Stock (2010-'11) Cayman S 2009 ITC, GTB1 (2012-15) 2000 Spec Miata (2014-15) 2016 Carrera GTS Current 2016 MB E-63AMG wagon Current 2015 Camaro Z-28 track car (modified) Current 2009 Cayman S GTB1 (couldn't stay away) Current |
09-28-2018, 10:14 PM | #10 | |
I modified a coil spring compressor to expand the spring and insert the spacer. The spacer is bigger than the space between the coils when the suspension is fully extended. They raise the nose about 1.5" give or take a little.
09-29-2018, 07:39 AM | #11 |
Drives: 2015 White Z28 Join Date: Aug 2018
09-29-2018, 01:53 PM | #12 | |
My car is in my trailer and will be coming out today. I will take some photos and post here when I remove the spacers.
10-01-2018, 10:24 PM | #13 |
To install and remove the spring spacers you need to jack up the car so the suspension is fully extended and then the spring must be spread more to get the spacer into the spring.
I use the tool in the photo below made from a strut spring compressor. You need to find a strut spring compressor with 5/8-11(NC) threads to get a nut to use as a spreader. Some have 5/8 Acme threads. The 5/8 Acme thread will not work unless you can find a nut that will fit the threads. Of the two spring compressors I found at a local auto parts store one was 5/8-11 and one was Acme thread. Both were the same brand. I used a 5" long 5/8-11 Carriage Bolt with the rounded head cut off for clearance, a 5/8-11 nut and a washer with the threaded and unthreaded portions of the compressor. The other photos are of the spacer installed and the spreader installed.
