Old 05-03-2021, 07:56 PM   #1
2010 SS Guy
Drives: 2010 Camaro SS
Budget friendly camshafts?
Looking for aftermarket camshaft for budget build, somewhere on 114 lsa. Please post what you got.
2010 SS Guy is offline   Reply With Quote
Old 05-03-2021, 11:36 PM   #2
low2001gmc
Drives: 10 Hurst SS Camaro, LOW2001GMC
Considering swapping out my like 100 miles Cam Motion 233-244, 646-637, 114+3, 8620 Cam...
Rob D on Facebook, Admin on several LS Sites and LOW2001GMC on Ls1Tech and PerformanceTrucks.net (956) 802 7700.
low2001gmc is offline   Reply With Quote
Old 05-14-2021, 12:32 AM   #3
SRMGT
Drives: Auto V8
I think people are going to need a bit more info... just saying 114lsa tells us nothing. A small 219/223 114lsa cam is drastically different than a 247/262 114lsa cam. The LSA is just a number that is produced after all the valve events are chosen. Are you looking for a small, stock stall friendly cam with no lope, or a big nasty cam that will get people's attention? What valve springs are you using? I'm in no way trying to be an a$$, just letting you know what info people will need. I have a used cam, but its a 236/250 .629/.604 117+4 from EPS. More of a blower cam, but I ran it NA for awhile and it had great driveability. Only has 1,200 miles on it. Make me an offer and it's yours
SRMGT is offline   Reply With Quote
Old 05-14-2021, 05:43 AM   #4
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
If you're building a twin turbo, I have a cam.
larry_g is online now   Reply With Quote
