02-11-2017, 05:04 PM | #1 |
Chevy/Cadillac Enthusiast
Need help and advice with my brake situation
The brakes on my '14 1LE are worn out, which is horrible timing and has me in a dilemma...
I will track the car, so I plan on upgrading to the black six piston ZL1 brakes this summer. Problem is, I don't think my brakes will last that long, and I don't really have the cash to upgrade now as I'm moving next month, and also have other expenses coming up this and next month. I thought about some short term options - either just replacing front rotors, just replacing front pads, or replacing front rotors and pads to buy time until I can get the ZL1 set up. If those options will not work I might could just go ahead and replace the rotors and pads all around $680 (OE stuff) and sell it when I upgrade. Or I can go with ACDelco Pro for around $354, but I don't want to compromise my stopping power with as much traveling as I will be doing, and living in a bigger city. If the pictures are in order, it's LR, RR, LF, RF, RF, RF. Hopefully you can see the lips on all four rotors, and according to a mechanic the pads have ~30% life. I have only put between 2 and 3k miles on it since I bought it (it has 81,500 on it) and I do feel a difference in braking, and a slight grind sometimes. I have never had to replace anything brake related before as I wrecked my Silverado and sold my Impala before they needed it. Any help or suggestions are greatly appreciated and needed! Thanks! |
02-11-2017, 05:10 PM | #2 |
Drives: Camaro Justice Join Date: Jun 2007
How many miles are on your rotors and how many road course days?
02-11-2017, 05:35 PM | #3 |
According to the CarFax, it shows "Brakes Serviced" at 6,645 and 8,957 miles, and nothing but "Brakes Checked" since. I believe the previous owner was 50/60+ years, and it doesn't appear he tracked the car based on the overall shape of the calipers and car itself. To put almost 79k miles on it in two years, it was mostly highway. So I would think the brakes are the original equipment unless something needed to be replaced those two times before 9k.
02-11-2017, 05:37 PM | #4 | |
02-11-2017, 05:41 PM | #5 |
So the rotors should be fine with lips on the inner/outer edges? A couple people I have talked to made it sound like a bigger deal. I was thinking pads would be the best route as well.
02-11-2017, 05:48 PM | #6 |
The ridges are clear signs of wear, stating the obvious. For a short term street use, I would roll with OEM pads and change rotors when it is time for the 6 pot upgrade.
02-11-2017, 05:52 PM | #7 |
Thanks!
02-11-2017, 06:49 PM | #8 |
Tri-County Camaro SWFL
Get the rotors checked with a micrometer only real way to tell if you need new rotors. You can always get the rotors turned/resurfaced, its pretty cheap to do and you can get some more life out of them for street use.
As for your pads, they are done...... all of those pics are the outter pad, the inner pads seem to wear faster. People sell brembo brakes on the classified all the time. Check there and see if any one has some used pads or ones they dont need. EDIT: may want to check this out. These are used but might help you out a little. http://www.camaro5.com/forums/showthread.php?t=474963
02-11-2017, 10:57 PM | #9 | |
Turning rotors removes material and is not appropriate for a performance vehicle. If the rotor needs to be turned on a performance vehicle, replace it. |
02-12-2017, 02:48 AM | #10 | |
By no means am I trying to undermine your advise or start an argument about this.
02-12-2017, 03:03 PM | #11 |
Thanks for your input, CamaroDreams76.
02-12-2017, 03:27 PM | #12 | |
Turning rotors on a performance car is one of the - Please Don't Do That - posts I have made so many times I got a little curt in my reply. Absolutely no offense intended. The next guy that posts I have less brake dust, no squeal and more stopping power is likely to get the same treatment I have posted on that subject even more frequently Between Facebook and forums I sometimes forget that this is the first time I am posting on this subject in a particular thread The guys in the shop start laughing when I am answering the same questions on the phone two, three four phone calls in a row. I and they have to remember that it is the first time the caller is asking the question and we are grateful they are calling. |
02-12-2017, 03:59 PM | #13 | |
I've come to you for help numerous times in regards to different upgrades, alignment, brakes, really anything suspension related so I for one actually take your advise. Especially when you build track capable Camaros for a living and I sure as hell don't. I just drive a Camaro back and forth to work and just started doing autox.
02-12-2017, 04:05 PM | #14 | |
Tags |
brakes, brakes & rotors, rotors |
Thread Tools | |
