Old 05-04-2014, 07:59 PM   #1
Chevy69er
Chevy69er's Avatar
Drives: 2011 SLP ZL-585, 13' Silverado
No reverse after 2nd gear burnout?
I have a line-lock and went to the track last week. Did burnout in 2nd gear(manual trans) with t/c turned off. Stabilatrak light comes on than trans wont go into reverse? Anybody else with this problem? If i shut off the car and restart its fine again??
Chevy69er is offline   Reply With Quote
Old 05-04-2014, 08:27 PM   #2
RxDoc08
Jason
RxDoc08's Avatar
Drives: 2011 2SS/RS M6
I've had the same issue. I also have a line lock and after a 2nd gear burnout I also couldn't get the car into reverse. I parked it after the run and it was fine after about 15 minutes. Not sure why this happens, but it probably has something to do with the line lock and the service stabilitrak message you get after the burnout.
Kook's headers w/ high flow cats, Borla S-Type, VMAX ported throttle body, CAI Inc. intake, Jannetty race scoop, Roto-Fab washer bottle relocation, Jannetty rough idle blower cam, DSS 9" w/ 3.70 gears, RPM Level 6 trans, Street Slayer Twin Carbon clutch, MGW Shifter, Pfadt trailing arms.
RxDoc08 is offline   Reply With Quote
Old 05-08-2014, 11:17 AM   #3
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Had the same problem, but with a 1st gear burnout at the track. No line lock. Shut off and restarted, it was fine.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 05-08-2014, 02:15 PM   #4
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
Interesting. Will watch this thread. I have no issues, although I don't think I have ever tried to get to reverse after a burnout with a line lock?
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline   Reply With Quote
Old 05-08-2014, 02:21 PM   #5
victoryred1ss
victoryred1ss's Avatar
Drives: 2010 SS M6 2016 2SS A8
Off the subject.. but what did you run at the track?? RMR im guessing?
TVS 2300 721RWHP 686RWTQ
Built by Me
Suspension done by JDP
Tune done by JRE
victoryred1ss is offline   Reply With Quote
Old 05-08-2014, 09:42 PM   #6
Chevy69er
Chevy69er's Avatar
Carson weve missed you on some cruises? Best is 11.7 at 6000DA. 1.95 60ft. times with 265/45/18 MT ET streets. Launching at 2500 RPM and still getting bad wheel slip in first and second. I need something allot more aggressive!!! I think it has 10.99 potential with some real rubber.
Old 05-08-2014, 09:44 PM   #7
Chevy69er
Chevy69er's Avatar
I was the first car out for test and tune and they didn't have the tree turned on so we both kept creeping up to trip the staging lite until we realized we were a foot past them so had to back up. turned the car off and restarted and went right in! must be the stabilitrak???
Old 05-12-2014, 09:22 AM   #8
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
I haven't tried to put it in reverse after using the line lock either, but it does make sense that it could lock you out if you confuse the computer. Good to know ahead of time! That would be distracting right before a pass.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 05-22-2014, 08:47 PM   #9
ZOOK
ZOOK's Avatar
Drives: 2010 2ss 6 speed
2010 2ss M6 & line lock ,,,,,
At the track on the weekend and had some issues as well. I did two passes in competition mode first time it would let me do a short burn out 3 to 4 sec.and then stopped . At the end of the pass all 3 liqhts are on (all nannys off ) had to let the car sit for 20 min. to qet them to qo out and the next time went to do a burnout and it let me do a John Force burnout all 3 liqhts on at the line but left in competition mode ???
ZOOK is offline   Reply With Quote
Old 05-23-2014, 08:12 AM   #10
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
YOU GUYS USING LINELOCK
Line lock solenoids interfere with the cars computer electronics.
You need to install a Transient Voltage Suppression Diode across the solenoid
Lingenfelter sells these part # L450080000
IDEALG is offline   Reply With Quote
Old 05-23-2014, 09:37 AM   #11
TornadoSS
WICKDSS
TornadoSS's Avatar
That's the first I've ever heard of that? The only issues that I know causes problems and disables the abs/traction control is the fact that the rear tires are spinning and the fronts are not. To my understanding that's what freaks the computer out. There is a way around it though by incorporating a relay into the mix by dropping the power off of the abs module during line lock arming. That way it's momentarily "blind" to the fact that the wheels speeds don't match.
Old 05-23-2014, 10:04 AM   #12
IDEALG
IDEALG's Avatar
When you grab power from the 4 gauge pack this happens. I've fixed the problem using the diode , it works just thought i'd share.
I turn all abs/traction controll off and everytime i used line lock the trac system would shut down and the button would do nothing until i shut the car off and and restart it. I asked around to some higher heads if they knew why this was happening and i got no answer.
Only when i bought a launch controller from LPE did i find out about the diode because they tell you to install in so the solenoid doesn't interfere with the launch controller..... Then i realized it was the solenoid interfering with my trac system.
Old 05-23-2014, 08:53 PM   #13
Slickcas
Drives: 12' 2SS/RS LS3 IBM
The way GM programmed these cars is to protect itself. If the computer sees something unreasonable ie standing still doing a burnout then pushing it on the clutch. The computers looking at zero motion but wheel speed is going very high then wheel speed will drop to 0. The computer will go into a sort of safemode. First thing it will do is lockout reverse. Because it does not think it can trust the cars sensors and does not want you going to reverse if the car has any forward motion. Usually after about a mile or so or 15 minutes driving to recalibrate everything it will let you go to reverse.
I do not use Line locks. And this has happened to me in the past at a dragstrip. After doing a lot of research this is what I found out.
Slickcas is offline   Reply With Quote
Old 05-24-2014, 06:43 AM   #14
TornadoSS
WICKDSS
TornadoSS's Avatar
After reaching the Tremec website I find this to be true about the reverse lockout. It does appear to have a speed controlled reverse lockout feature, so, that makes sense when the abs/speed sensors are freaked out. Thanks for bringing that up.
