Old 09-21-2017, 11:03 AM   #1
pony
pony's Avatar
Drives: 2011 2SS Convert; Color RJT
GPI SS1 VVT Time Lapse Cam Install
Recently made a trip down to Gwatney Performance Innovation to have a cam installed on my Camaro. Put together a time lapse video/vid of the entire process along with the dyno. This install was done in 1 day and the dyno the next morning. Thought this might interest some of you contemplating this upgrade.
pony is offline   Reply With Quote
Old 09-21-2017, 12:14 PM   #2
Jose131
Drives: 2015 Camaro SS
Do you mind sharing your setup and how much it costed you with everything + labor. I hear amazing things from gpi's VVT cams. Im seriously considering this cam on my car soon.
Jose131 is offline   Reply With Quote
Old 09-21-2017, 12:31 PM   #3
Hixson
Hixson's Avatar
Drives: 2015 Camaro 1SS L99
Agreed, would like the info on cost and stuff if that doesn't bother you. Considering this for a winter project while the car is parked.
Hixson is offline   Reply With Quote
Old 09-21-2017, 12:49 PM   #4
hammdo
'It's an experiment'
hammdo's Avatar
I just had GPI do a forged and stroked LSA for mine.. You'll love the SS1. I had it and it was awesome...
-Don
747 RWHP 794 RWTQ
Old 09-21-2017, 01:02 PM   #5
pony
pony's Avatar
I don't think it's a big secret, but everyones setup is slightly different. IF you already have headers, CAI, etc. AND do not have to install a stall converter, you are looking in the range of $4000-4400. This would cover parts, install, dyno tune, oil, gaskets, fluids, out the door for a basic VVT SS1 cam. Their website has the kits and prices and well as prices on rod mod intakes, etc. Hope this helps.
Old 09-21-2017, 01:03 PM   #6
pony
pony's Avatar
-Don
Was across the bay from you. James was supposed to introduce us, but never seemed to be there at the same time. You followed me on the dyno, but I was heading back north by then.
Old 09-21-2017, 01:13 PM   #7
hammdo
hammdo's Avatar
I told Aaron to call me early so I could come by and watch the startup but, they were so busy, slipped past them. I got there around 12:15 and Ryan was outside the Dyno bay running my car.. Would have like to meet... Two RJTs at the same time ;o)...
Hopefully next time you come down...
-Don
747 RWHP 794 RWTQ
Old 09-24-2017, 12:27 PM   #8
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Awwwesome! And what were your numbers? How does it drive now?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 09-24-2017, 01:37 PM   #9
rjs1le
Drives: 2014 2ss/rs/1le
Can't see the video, what do I need to do
rjs1le is offline   Reply With Quote
Old 09-24-2017, 04:37 PM   #10
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
I thought the front of the car had to come off. Glad to see it didn't! Seriously, I didn't think there was physically enough room for R&R.
Moto-Mojo is offline   Reply With Quote
Old 09-24-2017, 07:03 PM   #11
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
It doesn’t. You will need to carefully maneuver the A/C condenser up & out of the way to get the camshaft in/out.
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 09-25-2017, 07:24 AM   #12
pony
pony's Avatar
If you're trying a hand held device, that may be the problem. Try a PC?? It's also on youtube.
Final numbers were 452 rwhp/420 trq. NO problems with idle or surge, but still has a very nice lope/sound.
Old 09-28-2017, 01:12 PM   #13
LCPLPunk
USA-1
LCPLPunk's Avatar
Wowzers, outfriggin standing! So you gained about 80 hp?
Old 09-28-2017, 09:23 PM   #14
pony
pony's Avatar
Didn't do a baseline as so many stock L99's baseline around 330 rwhp (someone correct me if I'm wrong), so not sure what the break down for each bolt on is, but with ported TB, LT headers/high flows, CAI, SS1 cam, and rod mod intake, netted me roughly 122 rwhp.
Could've milled the heads and gotten another 10-20. Very happy about the numbers with a "safe" build for touring. Still getting roughly 23 mpg vs 24 pre cam. FYI It was tuned and dyno'd with post hi-flo cut outs open.
