Old 08-08-2012, 01:48 PM   #1
BigL11
BigL11's Avatar
Drives: 2011 Camaro SS
Thermostat 160
What does everyone think about them? Would it be worth it if I have a TVS 2300 on my car?
BigL11 is offline   Reply With Quote
Old 08-08-2012, 02:06 PM   #2
bmbbl be
bmbbl be's Avatar
Drives: 2010 CAMARO SS
livernois did my maggie set-up,,,and they put one in.....on the 95 degree days my car runs at 195 all day
bmbbl be is offline   Reply With Quote
Old 08-08-2012, 02:12 PM   #3
JANNETTYRACING
JANNETTYRACING's Avatar
We can achieve the same results with a factory 186 stat, it is in the Fan settings.
Radiator and fan settings set top Temp, Stat Sets Min Temp.
A lower stat is not recommended in this car for anything other than Racing, as it takes longer to get up to Min Optimum Temp which is set by the Factory engineers at 186.
The faster you can get up to 186 the less wear in your engine.
It is also a little known fact that Oil Additives do not become active until 180 degrees Oil Temp.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 08-08-2012, 04:34 PM   #4
MA2010SS
Drives: 2010 Camaro SS
I have one with my car and in the summer months it's running around 192 ~ 196deg range, I also have the fans turning on a lot sooner than stock settings, winter/colder months it will run around 178 ~ 184deg range
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 08-08-2012, 04:50 PM   #5
LSR SAL
LSR SAL's Avatar
Drives: faster than dirt...
Ted.
This man is correct!
LSR SAL is offline   Reply With Quote
Old 08-08-2012, 06:04 PM   #6
camslambam
Drives: 2010 SS, 06 SRT10 Ram
I got factory stat and down here it's always 90+. Car runs 190-195 all day long in 90-100F @80-90% humidity. (I live a block from the ocean).
camslambam is offline   Reply With Quote
Old 08-08-2012, 10:26 PM   #7
Higgs Boson
Perpetual Order
Drives: indeed
ok i have to chime in so take it for what it is worth. I have always thought the same as Ted regarding stats. for the hell of it, I threw a 160 in my camaro on Monday.
before it, I had my fans tuned to come one, one at 192/off at 190 and the second on at 200 and off at 198. you cannot program the fans to come on lower than 190 without a custom operating system. my car would run about 192-196 and right now temps are 104 or so with 50-60% humidity.
with the 160 in, the hottest I have seen so far, even in 104 temps, is 189 unless I am sitting at a light or in traffic it gets to low 190s. it gets to 185-190 just as fast as before. probably because it is hot as balls outside.... what this means is that my fans no longer run all the time. the only time a fan turns on is when I am sitting for an extended period of time. I haven't needed the second fan yet at all.
now, come winter time, we will see if I freeze my nuts off and never regain feeling before I reach my destination or if it the heater works ok....will update at that time. however, it doesn't get outrageously cold here nor does it stay retarded cold for very long at a time, usually it will get back to the 60s or so before cooling off again.
the reason for this observation is because thermostats do not click open and click closed. they open and close gradually. the 160 just begins to open sooner and is open more at 190 than the stock thermostat. I thought it was interesting that my car heated right up and then just doesn't really get into the 190s even when it's very very hot outside.
ymmv.
Higgs Boson is offline   Reply With Quote
Old 08-08-2012, 10:45 PM   #8
infernometallicSS
infernometallicSS's Avatar
Drives: 2012 Camaro SS Best Run - 10.93@125
Ted.
This is so true. My tuner advised against doing it also. I was driving around in traffic today in Phoenix and my coolant temp was 196 with the stock t-stat. The ambient temp was 116. My fans are set a bit lower though. As Ted says "it's all in the tune"
infernometallicSS is offline   Reply With Quote
Old 08-08-2012, 11:05 PM   #9
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Interesting. I have custom programming now and I think the lowest I've seen while sitting in the staging lanes at the track is 194F. And my fans come on and off all the time. I'll have to keep this info in mind for the future.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 08-09-2012, 10:12 AM   #10
Higgs Boson
Perpetual Order
Drives: indeed
remember, custom operating system is different than a custom tune. it costs even more to change the OS completely, and it can't be done on every car. for example, there is not one available yet for my car, the specific OS from the factory in my 2012 SS must be re-engineered. there are more than one factory OS in the E38s or any other ECM, per model year. so it can take a while to get a custom OS, and you have to request it. so it is best to check if it is available and then "order it" so to speak w/HPtuners or whoever you use.
if you are sitting in the staging lanes, turn car off, hood up and push it! this is where an electric water pump or manual control of your fans is great. you can turn them on while the engine is off. this will help your ECTs but also your IATs.
Old 08-09-2012, 11:05 AM   #11
JANNETTYRACING
ymmv.
I see you mentioned separate fan settings for each this would not be a Gen5 ECM
Which means the stock stat was probably a 192 in your car, Correct me If I am wrong.
The Gen5s all have 186 Stats Stock
Ted.
Old 08-09-2012, 11:09 AM   #12
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
Yeah I believe the corvette can run separate fan setting but not the Camaro correct?
JLE58 is offline   Reply With Quote
Old 08-09-2012, 11:09 AM   #13
Higgs Boson
Perpetual Order
Drives: indeed
Ted.
Well, I THINK my car is a Gen5 Camaro. lol...
I'll post a pic give me a min.
Old 08-09-2012, 11:24 AM   #14
Higgs Boson
Perpetual Order
Drives: indeed
Alright, here is a screenshot. This is modified. Here is what it means.
Fan 1 comes on at "50"
Fan 2 comes on at "90"
Fan 1 turns off at "25"
Fan 2 turns off at "50"
Therefore
Fan 1 turns on at 196 and off at ~193
Fan 2 turns on at ~202 and off at 196
If my car does not see 190 unless I am sitting still, that means my fans are not On at all unless I am sitting still, and even then it is only Fan 1.
Now, if you are saying the Gen5 turns both fans on and off at the same time (meaning you are not saying the controls are not there, they clearly are) then that's fine, but moot, since my point is not about the fans, it's about the thermostat reducing ECTs at least 10 degrees. I can't tell unless I had programmed the fans to stay off until 230 and see where the temps go with the stock stat with no fans. The fans were always working with the stock stat installed helping to keep the car in the mid 190s. Now it stays in the 180s without the fans. I would consider this a meaningful difference.
I will also add that with a custom operating system, the fan vs ect table is rescaled to 160 degrees which means you can get those fans on even before 192! Cool.
