#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Transmissions
Old 01-11-2016, 01:23 PM   #1
jaymsu
Yeti's Daddy
jaymsu's Avatar
Drives: ATS-V, Prowler, M6 V10
CAGS (Skip Shift) eliminator?
Did any vendor come up with CAGS eliminator for Gen6 Camaro yet?
If anyone knows of one, please let me know. Thanks!
2SS Nightfall Grey /Adrenaline red interior
NPP / MRC / Nav / 6 Spd
1100: 7/27/15 <SSWNNN>
3000: 9/04/15 <TPW:10/19/15>
3800: 10/19/15 <VIN: 117740>
6000: 12/16/15
jaymsu is offline   Reply With Quote
Old 01-11-2016, 01:27 PM   #2
drivingagain
drivingagain's Avatar
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ!
I always wondered if this was a big deal. I have read so many posts about the skip shift and I have found on my 1SS it really is not that big of a deal. I have only had it tell me to go to 4th gear once while driving and noticed you can still go to the 3rd anyways. The reason I bring this up is to maybe understand why so many people really need the skip shift eliminator? Maybe my driving style is more aggressive in first gear?
drivingagain is offline   Reply With Quote
Old 01-11-2016, 01:29 PM   #3
FlightSoftware
Drives: '95 Corvette, '06 Mustang, 2LT RS
It's a bigger deal on cars that prevent you from going into second. I don't have an SS, but isn't the warning just that... a warning, but you can still shift into second if you want?
FlightSoftware is offline   Reply With Quote
Old 01-11-2016, 01:32 PM   #4
Jstyle
Drives: 2016 White 2SS on order
I've seen the warning several times on the display but it's never forced me into 4th. My other Camaro's Gen 4 and 5 all made me go into 4th if I babied it.
2SS White\Red 6M
Jstyle is offline   Reply With Quote
Old 01-11-2016, 01:57 PM   #5
C5Txfan
C5Txfan's Avatar
Drives: 2004 Corvette
Unless it's been changed from the Corvette C5 & C6 the CAGS forces you to shift to 4th. I don't care for it in slow traffic or turning a corner slowly and want to shift out of first. You're going too slow for 4th and will lug car down.
C5Txfan is offline   Reply With Quote
Old 01-11-2016, 02:02 PM   #6
fastball
Banned
Drives: 2017 Camaro 2SS 6MT
CAGS slips out a pin in the gear box to force the gear shift from 1st to 4th. GM has used CAGS on all 6 speed manual transmission/V8 engine combos since the 1990 Corvette ZR1.
If GM has done away with this pin and just uses an advisory in the DIC, that's a win/win/win for everyone!!
fastball is offline   Reply With Quote
Old 01-11-2016, 02:12 PM   #7
Camaro1LTBA
Drives: 2016 Camaro
In my short drive so far in the new Camaro the 1->4 came up a few times, but easily shifted into second, third, etc. Definitely a smooth shift, wasn't forcing anything.
Curious if anyone can confirm that it locks the gear or just simply displays a warning? Maybe it was just on and I went over the RPMs to avoid it? Hmm.
2016 Camaro 2SS Manual
Hyper Blue/Ceramic White
Nav, MRC, NPP, Black 5 Spokes
Escort MAX 360
Camaro1LTBA is offline   Reply With Quote
Old 01-11-2016, 02:13 PM   #8
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
How do you know it didn't exactly?
Definitely, but I'm pretty sure they haven't either.
Current: '17 2SS Hyper Blue, A8, MRC, NPP
Past: '99 SS Camaro A4, '73 Camaro 383 A3
"Voices in your head are not considered insider information."
3800 Status - 6/16/16 (Built!)
6000 status - 6/29/16 (Delivered!)
SuperSound is offline   Reply With Quote
Old 01-11-2016, 02:30 PM   #9
lDejavul
lDejavul's Avatar
Drives: Camaro SS
Ive gotten the warning and no pin but I've also gotten the warning and was forced into 4th. I would say out of the 2 months I have had it I have only gotten the warning maybe 20 times and only forced into fourth maybe 10. There was one time where I got the warning but must have shifted weird and with the clutch all the way down I made it into the second spot but it wouldnt let in it go into gear. its was grinding the gear like I was going into second without the clutch pushed. I had to pull back into neutral then fourth.
Adrenaline Red
20" 5 Spoke Black
Black Side Spear
Dual Mode Exhaust
MRC
Splash Guards
1G1FG1R74G0124089
lDejavul is offline   Reply With Quote
Old 01-11-2016, 02:35 PM   #10
jaymsu
Yeti's Daddy
jaymsu's Avatar
I also noticed that it allowed me to go into 3rd, which is different than with my C5 and C6. (before putting in CAGS eliminator)
I know you can shift out of 1st either earlier or much later, to avoid it, and I know it doesn't bother some people.
Well, it does bother me, so I want to find a solution to give me a FULL freedom to shift the way I want.
Anyone has either harness or fuse for this yet?
6000: 12/16/15
Old 01-11-2016, 03:10 PM   #11
fastball
Banned
Unless the new Alpha architecture has changes so significant the old harness won't fit anymore, here's the harness for the 5th gen Camaro SS:
http://www.amazon.com/CAGS-Bypass-Sk...ags+eliminator
Old 01-11-2016, 06:42 PM   #12
BlkReaper
Drives: 2016 2ss
When I first got the car I had it lock out 2nd on my a lot. Tgen I just started holding in 1st gear longer. The message will still come up but if you pass a certain rpm you can go to 2nd
BlkReaper is offline   Reply With Quote
Old 01-11-2016, 06:58 PM   #13
tejesh83
Drives: 2016 Camaro 2SS
I've seen the message pop up a few times but it still seems to let me shift into 2nd. I never even noticed the skip shift... I guess I'm driving to aggressive =)
2016 2SS - Summit White - MT - NPP - MRC - NAV
tejesh83 is offline   Reply With Quote
Old 01-12-2016, 10:06 AM   #14
Jstyle
That's what I'm saying. Even though the message pops up it has never forced my into 4th.
2SS White\Red 6M
