06-08-2018, 04:37 PM | #1 |
Drives: 2015 1LE Join Date: Oct 2015
Texas Speed Cam Dyno
Dyno results are in. Running a Texas Speed 225/236 .629/.615 cam, ported factory heads and all the bolt-ons. Cam made great power with awesome drivability. Car is a 1LE.
06-08-2018, 04:46 PM | #2 |
Drives: 14 ss camaro summit white Join Date: Oct 2014
Damn a bit shy of 500 good numbers
2014 ss camaro
Stainless works long tubes , rotofab cai , vararam wedge , muffler delete,cat delete ,resonator delete , x pipe 2019 sierra duramax 2500 all terrain x 2001 trans am Lsx 408 ci rebuild in progress(dead project) 1967 camaro Sbc 327. |
06-08-2018, 05:11 PM | #3 |
06-08-2018, 06:09 PM | #4 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
nice numbers..should be shiftin at 7k so get the limiter set to 7200..bottom end is fine and as long as you did all the good things to the valve train...should be golden!
peace
06-08-2018, 06:33 PM | #5 |
I wish I would have put in good johnson lifters, these LS7 are kinda noisy, although they might work they are not quality enough for aftermarket cams and higher spring rates. I might swap them out next winter along with some jesel shaft rockers so I can fine tune the preload.
06-08-2018, 11:07 PM | #6 |
Drives: 2015 Camaro 1LE Join Date: Sep 2015
Congrats, nice numbers. Now it's time to enjoy that new found power!!!
06-09-2018, 07:21 AM | #7 |
06-09-2018, 07:29 AM | #8 | |
06-09-2018, 08:37 AM | #9 |
Yes, its a LS3 car.
06-09-2018, 09:26 AM | #10 |
Ive got a buddy with Johnson lifters. Sounds the same
06-09-2018, 09:37 AM | #11 |
Thanks for the tip! I guess I am really picky and should leave well enough alone, the dyno shop said the car sounds perfectly fine.
