03-27-2016, 06:01 PM | #1 |
Voltage question
So I just installed my blackvue dash cam and set it to cut off when the voltage drops to 12v. Here's my question I just realized that with the car running the voltage hovers at 12.3 and 12.2 is that normal? It just seems low to me and wonder how long it'll take a dash camera to make it drop to 12.0.
03-27-2016, 06:42 PM | #2 |
Drives: 2011 RS Join Date: Apr 2011
My 4pack gauge cluster has mine between the 12 and the 19 at all times. Do you have a 4pack cluster?
03-27-2016, 06:47 PM | #3 |
I do but like a jackass I did this almost a year ago when I got my vtc
03-27-2016, 06:48 PM | #4 |
But I can see it in the vehicle info menu.
03-27-2016, 07:13 PM | #5 |
Drives: 2015 Z/28; 1969 Camaro SS Join Date: Nov 2015
These cars should charge at ~14VDC while running. It will fluctuate but you should only see 12.2 range when the car is not running but key is on.
03-27-2016, 07:19 PM | #6 |
Okay it was at 12.3 as soon as I started the car. I have the dash camera connected to a power magic pro so I'm hoping it doesn't kill the battery as that would suck. Any idea how long the camera could record before the voltage drops to 12 and the camera shuts down? And thanks for the response I appreciate it.
03-27-2016, 10:15 PM | #7 |
you should get the battery and alt checked.
03-27-2016, 11:15 PM | #8 |
03-27-2016, 11:29 PM | #9 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
This ^^^^^ -- if it is reading less when running I would have the alternator & battery checked.
03-28-2016, 08:24 AM | #10 |
I started it this morning and everything seems to be reading where you guys said it should I guess yesterday was just a bad read? The first pic is immediately after starting and the second is after a few minutes of driving.
03-28-2016, 08:26 AM | #11 |
You use that menu button until you get to the performance screen and after that you scroll to the screen with coolant temp and battery voltage.
03-28-2016, 06:04 PM | #12 |
Nope...not on mine When I get into the Vehicle Info Menu I get Coolant temp but no Volts, maybe because it's a LS3 , a '13
03-28-2016, 06:08 PM | #13 |
Drives: 2015 Camaro LS Join Date: Jan 2016
There's nothing wrong with the charging system on these newer Camaros, the charging system was designed to save the battery life, once the system see that the battery is fully charged it cuts back on charging the battery. As long as it is 12.4 or higher you really shouldn't worry, now if it goes below that and stays there then you have a problem.
15 LS in Blue Velvet
03-28-2016, 07:12 PM | #14 |
Drives: 2013 2SS (sold) Join Date: Jan 2016
After our year they upgraded the DIC to give more info, so sucks for us lol
Track Parts/Stock Parts Part Out http://www.camaro5.com/forums/showthread.php?t=515534
