Old 01-18-2024, 05:39 PM   #1
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
AC Delco PCV Valve part # 86KD73T
Why are the parts stores not carrying this universal part for many GM vehicles? Seems to always be 0 in stock. Then when I go to check online through various sources for this part... it will take a week or two to arrive. What gives? I'm looking into getting this new PCV Valve so I can drill larger holes and install for my new oil catch can. Are there any other part numbers that will work as well that is compatible for the 2010 Camaro LLT 3.1 V6?
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 01-18-2024, 08:34 PM   #2
SummitWhite11
Drives: 2010 2LT/RS
Looks like I may have found one locally and placed my order online to pick up tmw. Will see what happens then....
2010 2LT/RS
Old 01-19-2024, 07:41 AM   #3
redcoats1976
wonder if its compareable to the newer version from 2013 up that already has the bigger holes?
Old 01-20-2024, 01:13 PM   #4
SummitWhite11
Drives: 2010 2LT/RS
Not sure because when i inquired about it awhile back it was stated as not compatible via parts stores or online. Not sure why. Anyhow the pcv valve I just recently picked up yesterday is a carquest part from advanced auto parts. Not sure if it makes a difference if its ac delco or not.
2010 2LT/RS
Old 01-20-2024, 04:18 PM   #5
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
It shouldn’t
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 01-20-2024, 06:01 PM   #6
SummitWhite11
Drives: 2010 2LT/RS
Originally Posted by Wizard1183 View Post
It shouldn’t
2010 2LT/RS
