08-09-2021, 11:45 AM | #1 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
9 inch vs Strange S60 vs ZL1
I'm trying to upgrade the rear before it blows to bits. I was going to do the ZL1 diff/axles, but for one, they are increasingly harder to find. I also know of 2 people who just snapped a stock zl1 half shaft with less hp/tq.
It's not a cheap upgrade, so I am trying to do as much research as possible before i buy. I spoke to a few guys and a couple vendors, but was looking for more opinions from people who regularly drive/race with any of the following: DSS 9inch G-Force 9inch Strange S60 ZL1 diff and axles I can't find anyone currently that has a ZL1 kit, as they appear to be discontinued. So it would have to be Used, plus would probably need new 1400/1500hp axles. What do you run? What have you broken? Do all aluminum fab'd 9inch housing move the pinion angle?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
08-09-2021, 01:18 PM | #2 |
Boosted Moderator
I run the DSS 9” pumpkin, with a strange center section and a wave track diff, and 32 spline axles.
Bullet proof is an understatement… It has a 1350 yoke, which also came with my transmission. I had a 4” 1 piece aluminum driveshaft built and I run the DSS 1400 HP axles….. With 2000 + RWHP, I’ve never had an issue…I can show you carnage with other parts of the driveline, like a badly twisted 300 M transmission input shaft…. I dead hooked at Lucas Oil Raceway and well… Time for a new shaft…. Diff laughed at the transmission…
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
08-09-2021, 02:04 PM | #3 | |
Is there a middle ground between toothipick axles and popeye arms?
08-10-2021, 05:59 AM | #4 |
Interested in this as well as I broke an axle on Saturday and contemplating my options.
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, RPM 5” CAI, Kooks Headers, Solo Cat Back, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
08-10-2021, 07:05 AM | #5 |
I'd like to hear from people who are pushing the ZL1 diff. Weather its with stock zl1 axles or upgraded. I have a feeling it might be a good fit for me.
What is the spline count on the Zl1 axles? Are the aftermarket axles for a Zl1 diff, the same ones that fit the S60 or 9inch stuff?
08-10-2021, 07:55 AM | #6 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
The ZL1 axles would not be that bad if you could get new stubs when one snapped. I was on eBay looking at Gen6 ZL1 axles, which are much more plentiful and cheaper than GenV ZL1 axles. The Gen6 outer "looks" the same as the GenV and is 33 splines going into the hub like the GenV. I would be curious to know if the outer stub is interchangeable. I know there are not a lot of ZL1s out there, but it seems like someone would sell the parts to fix the factory axle rather than buy a Surtrack Chinese unit.
I have all the BMR stuff including subframe connectors to prevent wheel hop and it still snapped when I moved to slicks, so I would say if you run ZL1 axles, stay away from slicks.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
08-23-2021, 12:50 PM | #7 |
I ended up with this from Ebay. With the driveshaft and shipping was about $3k. Also had to buy the trans flange and some hardware, diff fluid, sockets.
Do you think i should swap out the diff bushings? These things look brand new. I guess if i dont want them flexing I should get some bmrs.
08-23-2021, 01:03 PM | #8 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
I would swap the diff bushings to BMR red poly.
You could always order beefier axles and run the OEMs until they arrive.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
08-30-2021, 09:56 AM | #9 | ||
Still waiting on the damn trans flange to Propshaft NUTS... then I can test fit my exhaust. Hope it clears, this pumpkin is like twice the size of the stocker.
09-07-2021, 10:11 AM | #10 |
Well that sucks. Gonna have to reroute my drivers side exhaust piping. This pumpkin is huge.
On a positive note, the little testing i did felt great. I rolled into the throttle in second gear and the ass didnt come sideways. I could feel the LSD switching power from left to right side. Huge improvement, and the 3.73s feel great! I noticed before i pulled the stock axles, that if I spun one wheel, the other wheel would spin the opposite way. But with the zl1, they both spin the same way. Is this normal?
10-04-2021, 06:46 AM | #11 |
Drives: 1966 Chevelle Join Date: Oct 2013
[QUOTE=
I noticed before i pulled the stock axles, that if I spun one wheel, the other wheel would spin the opposite way. But with the zl1, they both spin the same way. Is this normal?[/QUOTE] I believe that’s due to the posi unit. But wasn’t your original rearend posi too?
66 Chevelle with 2013 LFX V6, 6 speed auto, full Hotchkis suspension, Wilwood 4 wheel discs.
10-04-2021, 09:45 AM | #12 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Sounds like something was broken, both wheels should spin in the same direction with our LSD
10-13-2021, 05:15 PM | #13 |
Got the exhaust rerouted, but now Im throwing C0050. Tripping ABS/stabilitrac/TC and all that. Guess I'll throw two new rear hubs (with abs sensor rings) and abs sensors at it.
Can't seem to get this code to clear...
