03-12-2021, 02:25 PM | #1 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Got the new drag radial
I purchased the new Nitto drag radial. It's called the 555RII now. They were around 650 a pair shipped. Hopefully I can make the Atco opening on the 27th.
I will say I had no issues with the old Nitto drag radial the 555R. I got dead hooks on the track so I plan on doing a comparison on them.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
03-12-2021, 03:00 PM | #2 |
Drives: 2015 2SS A6 Commemorative Edition Join Date: Nov 2019
Nice! $650 a pair seems comparable with the price of the 555r if I remember correctly. Please let us know how you like them.
03-12-2021, 05:41 PM | #3 |
Drives: 2011 Camaro SS Join Date: Jul 2017
What size ?
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
03-12-2021, 07:25 PM | #4 |
Very cool bro. Good luck with them and let us know how they compare.
03-12-2021, 07:36 PM | #5 |
305/35/20 Once I figure out what drag setup to get that will change though.
03-12-2021, 08:31 PM | #6 |
Those are supposed to hook even better than the 555R’s. Looking forward to hearing your feedback, I might go back to those on my 20” setup for driving around town.
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, RPM 5” CAI, Kooks Headers, Solo Cat Back, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
03-12-2021, 08:52 PM | #7 | |
If these are even better I'll be very pleased. Should be here Monday, track opens the 27th, when CSP finishes my car? Hopefully next week as well.
03-13-2021, 05:21 PM | #8 |
Drives: 2015 camaro 2ss, 87 monte ss Join Date: Jun 2016
I have had mine since January and slap them on for the weekends and track. They will help drop that 60ft for sure over a summer tire. Love mine. I just have the stock tire size on an extra set of factory wheels but they cut .3 tenths off my 1/4 over the summer tires and got this bolt on and stalled L99 into very low 12s and I have driven them in the rain and have no problem with traction being sensible with my right foot.
03-13-2021, 05:37 PM | #9 |
They work great for me! No complaints here. |
03-14-2021, 07:25 PM | #10 | |
03-14-2021, 10:18 PM | #11 |
If you get traction and a decent 60ft I don't see how you can't be in the 10s with that set up. I have seen L99s with the gpi ss4 vvt, big stall over 4k, gears, tires, the whole setup with good track prep and good air run 10.8-11.2 all night long, so you should have deep 10s in there for sure. I think most of those guys I saw at HRP were running about 500rwhp NA. With your ecs I assume you are 600-750rwhp? You defiantly have the power.lol
03-15-2021, 08:05 AM | #12 |
I ran an 11.40 on a conservative tune last year.
03-15-2021, 10:01 AM | #13 |
My morning present from Fed Ex.
03-15-2021, 12:12 PM | #14 |
You should definitely be in the 10s. If you can't pull a 1.6 or better you are surely traction limited. If you still have a problem after your next run getting in the 10s I would drop from 20inch wheels to 18s or smaller. While everyone says 18s make a huge difference I haven't seen that at my power level. I think the skinnes are what matters most for someone with my setup but at your power level both probably are worth more than a tenth easily.
Also, I noticed the 3.91 gear. That is a ton of gear for a blower car with your power and I have no doubt it is fun from a 30 pull but it is almost to much of a good thing with all that low end torque if wheels, tires and suspension aren't perfect. I would check into some 3.45s as they are factory replacement and can be had for cheap. If this is ultimately a street car and cruiser than a 3.91 will be the hot ticket and should be the fun gear but at your power level it's hard to get that all down without a perfect setup. It might actually be slowing you down. Data log it all and I would play with the PSI. I am sure 18-26psi will be the sweet spot. But start at like 26psi and work your way down 1psi at a time. I have never run below 18psi and I got no 60ft gain for me going to 18psi. I think for me 24-26psi was the sweet spot but I don't really need them that low for my power level. Really once I added the bushings and BMR rear suspension it was night and day, the nittos are just icing on the cake at this point. A lot more skill and prep involved in a car with your power level. I am pretty sure anyone off the street could get my car in the low 12s after a few passes. Good luck and keep us posted! |
Thread Tools | |
