Old 02-21-2020, 04:04 PM   #1
Mhorn0817
Drives: 2011 Camaro ss
Trans cooler line routing.
Can anyone take a picture of how the trans cooler lines, oil cooler lines, etc are ran and where they snap into on a 2010 Camaro SS, automatic. Not sure exactly where the factory cooler mounts.
Mhorn0817 is offline   Reply With Quote
Old 02-23-2020, 09:54 AM   #2
Mhorn0817
Or is someone in Maryland that I can look at and see for myself?
Old 02-23-2020, 12:23 PM   #3
2010reddevil
Drives: 2010 Camaro 2SS Victory Red 6M
They are directly on the driver's side the trans and go up the right side towards the middle/bottom of the radiator.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19
Gone on 12/28/19 R I P
2010 2SS 6M Victory Red/Black (old ride)
CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back.
12.6 @ 115 SAR as of 9/19/15
Gone but never forgotten.
2010reddevil is offline   Reply With Quote
Old 02-23-2020, 06:54 PM   #4
Mhorn0817
Where does the cooler mount?
Old 02-23-2020, 08:03 PM   #5
Coz3z3
Drives: 2015 Z/28, 2015 1LE
Pretty sure there isn't an external one, it's all in the radiator. I could be wrong though. I cant remember on the tranny one, but know the oil cooler goes to the radiator.
Coz3z3 is offline   Reply With Quote
Old 02-24-2020, 08:08 AM   #6
Mhorn0817
Ah, maybe that's why I'm confused. Guess it has an aftermarket external cooler. Lol
Old 02-24-2020, 11:28 AM   #7
GAD
GAD's Avatar
Drives: Silver 2014 Camaro 2SS
I installed an aftermarket trans oil cooler. I mounted it on the front of my radiator. The trans oil lines came out of the bottom, drivers side of the radiator and went back to the trans.
2014 Silver 2SS L99 with Roto-Fab CAI, Kooks LT Headers, Kooks Cat-less 3” exhaust, TS Stage 3.2 VVT CAM, Circle D 3200 Stall, E85 Kit, FIC 850cc injectors and Elite Engineering Catch Can. Dynoed at 478rwhp.
GAD is offline   Reply With Quote
Old 02-24-2020, 12:18 PM   #8
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
I have some good pics of lines and an aftermarket cooler install in my GPI build thread on here. Check it out. Hope it helps
gunchamp is offline   Reply With Quote
Old 02-24-2020, 12:19 PM   #9
gunchamp
gunchamp's Avatar
Also, mine has the lines coming from the pass side into the bottom of the radiator in factory form
Old 09-08-2021, 08:11 PM   #10
iwa_jogja
Drives: 2015 camaro LT
Hi, so the flow is from transmission to passenger side of bottom radiator, then come out from driver side back to transmission? Is it correct? Return line from driver side. I want to install trans cooler. Thanks
Sent from my SM-G973F using Tapatalk
iwa_jogja is offline   Reply With Quote
Old 04-16-2024, 03:27 PM   #11
SFR7771
Drag and Drive is Life
SFR7771's Avatar
Drives: 2010 Camaro 2SS RS A6 LS3 Whipple
Did you ever find out what side is return!
My build link... https://www.camaro5.com/forums/showt...4#post11077544
2010 2SS/RS/ Mods, Whipple, 1000cc injector, 102MM TB, Innovation West 10% OD pulley set up 8 rib, AGP twin 450 fuel system w flex on E85, CAI K&N, LT with OR Cats aka no catalytic converters, Coils and wires, 3" exhaust with mufflers, Oil catch can, 2015 ZL1 9.9 3.23 ratio, BMR upper Lower control arms, 15"conversion, BMR Anti Roll Bar 315/60/15 ET street slicks
1972 El Camino SS 565BBC 950HP, All TRZ suspension
SFR7771 is online now   Reply With Quote
