07-24-2016, 09:51 PM | #1 |
Drives: 2013 1LE Join Date: Jan 2013
295 wide on front wheels
How bad is the rubbing going to be on a 1" lowered stock strut with about -2.0 camber with 295 tires on the front. Stock 1LE/Zl1 wheel.
I'm assuming there is no issue with the rears with this size. Abdi |
07-25-2016, 11:32 AM | #2 |
Drives: 2015 2SS/RS/1LE Join Date: Jun 2015
Tire choice may come into play as some run wider than others.
I just lowered 1" and I feel like the rear might be more of an issue when I feel the space with my hand. But I am still waiting to do an alignment. I think I will have tire kingdom try to install the NT555 G2's in a 295/35/20 and 315/35/20 combo. No clue if that is a smart choice or not. I heard Nittos ran narrow but when I compared them to the Mich PSS, they seemed very similar in their measurements. So now I'm worried but I was told it was a no risk approach. If the tires don't fit, no obligation to buy them. |
07-25-2016, 01:47 PM | #3 |
I don't have it lowered but I have 275/40/20 in the front and 315/35/20 in the rear and in the rear I still have space to drop it if I want to. but the fronts look extremely flushed but I know it won't rub.
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries) Procharger D1x with a 3.85 pulley ID1050x Injectors Flex Fuel Sensor Monster LT1 Twin Disk Clutch Holley Sniper Efi Intake Manifold NW 103mm Boosted TB 747rwhp at 12psi on E85 |
07-25-2016, 01:59 PM | #4 |
When you say you have space in the rear to drop it, you are referring to the height of the tire, correct? I personally am not as worried about the tire height, it's more about the width and whether it rubs on the inside of the wheel well. Even lowered with the Hotchkis, there is plenty of room height wise in the rear.
07-25-2016, 02:17 PM | #5 |
Drives: Camaro Justice Join Date: Jun 2007
295/30/20 will be fine all round.
07-25-2016, 08:14 PM | #6 |
Drives: 2014 SS1-1le Crystal red metallic Join Date: May 2015
I did 295/35/20 Nitto Invo's! I like them a lot
07-25-2016, 08:31 PM | #7 |
07-25-2016, 10:23 PM | #8 |
Drives: 15 2ss 1le Join Date: Mar 2015
07-26-2016, 09:00 AM | #9 | |
Specs
07-26-2016, 09:07 AM | #10 |
Drives: 2010 Camaro SGM 1LT M6 Join Date: Jan 2015
you'll have plenty of space. I'm lowered 1.25" all the way around and run a 275/40R20 and 315/35R20 with no rubbing even at full turn
Arkentect's Build Thread!! - UPSTATE C5 MEMBER
2010 SGM M6 1LT - SOLD Current - 2009 C6 Corvette Z51 |
07-26-2016, 12:21 PM | #11 |
07-26-2016, 12:22 PM | #12 |
Stocks are better !! But I do like these invo's
07-26-2016, 12:26 PM | #13 |
And would I have been better off going with 295/30/20's?? Thanks
07-26-2016, 12:44 PM | #14 |
