Old 05-14-2021, 01:05 PM   #1
Folbjo
Drives: Camaro SLP ZL575
Rims for Camaro 5th Gen from a 2016-2018 model
I'm looking for rims for my 2010 Callaway Hendrick Motorsports 25th Anniversary Camaro. I have been in contact with Callaway with a request to purchase one set of extra rims for this. Callaway then said that rims for this model had gone out of range, and could no longer be purchased.
Came across photos of the Callaway Camaro SC630 (2016-2018)
This car had black rims in Callaway's classic design with 9 spokes.
Exactly such rims I want !.
Then I come to my question to you; do rims from a Camaro 2016-2018 fit on a 2010 model?
Folbjo is offline   Reply With Quote
Old 05-14-2021, 02:13 PM   #2
Lablkv6z
Lablkv6z's Avatar
Drives: 2000 Camaro SS, 1966 Mustang
I've seen stock 6 gen wheels bolted on 5 gens with the use of a 5mm spacer.
https://www.youtube.com/channel/UCR-c7C5jMcEEQ4y_YaXMD6Q
LS3 Block (427CI)
Forged Manley 4.1" crank
T-Rod modded LS3 intake (by me)
Ported 821 heads (by me)
TSP cam 243/255 .621/.619 111 LSA
HP tuners pro (by me)
https://www.smokingasphalt.com/
https://www.youtube.com/channel/UCR-...cEEQ4y_YaXMD6Q
Lablkv6z is offline   Reply With Quote
Old 05-14-2021, 02:43 PM   #3
Folbjo
Do you have to use a spacer?
Do 5th gen and 6th gen have different offsets on the rims?
Old 05-14-2021, 03:04 PM   #4
Lablkv6z
Lablkv6z's Avatar
Yes, they'll rub the calipers without spacers from what I've read. 3mm spacer would be the minimum. The tires are shorter on the 6 gen wheels too.
https://www.camaro5.com/forums/showt...=446314&page=5
LS3 Block (427CI)
Old 05-14-2021, 05:56 PM   #5
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Mine didn't need spacers. No rubbing.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 05-14-2021, 07:11 PM   #6
BLU DUCE
BLU DUCE's Avatar
BLU DUCE AKA=Spike III Build
Yes they do.
Old 05-14-2021, 10:53 PM   #7
Camaro fanboy
Camaro fanboy's Avatar
Drives: 2017 2SS Arctic blue fully loaded
some gen6 wheels are killer. mine look super and will never change them.
rear tyres are a little smaller on the sidewall though. 35mm on the gen6 and 45mm on the gen5. think so anyway.
good way to make a gen5 camaro look good is to fit gen6 wheels
Camaro fanboy is offline   Reply With Quote
Old 05-15-2021, 11:57 AM   #8
Folbjo
Does anyone know the correct dimension and offset of the Callaway's rim for the Camaro SC630? (Black rim in the first post)
What is the dimension and offset of the original rims for the 6th gen?
Old 05-15-2021, 10:03 PM   #9
ccss713
Drives: 2010 2SS
I have 2 sets of 6th gen 5 spoke wheels on my 2010. I use the 4 rears in the summer and 4 fronts with snow tires. No spacers, no problem. I have taken the rears on the track (road course) twice now also
Edit: Turns out my fronts were rubbing my 1le struts and now I run 5mm spacers (and longer studs) in the front.
ccss713 is offline   Reply With Quote
Old 05-17-2021, 08:04 AM   #10
Yellow 1
Grumpy Grey-haired Guy
Yellow 1's Avatar
Drives: Camaro, Corvette & Merc C300(daily)
I have a set of MMR 6th Gen ZL1 replicas on my 2013 SS - bolted right up.
Yellow 1 is offline   Reply With Quote
Old 05-17-2021, 09:26 AM   #11
Camaro fanboy
nice to see a camaro in blighty. bet you get a lot of compliments?
