11-04-2021, 06:49 AM | #1 |
Fuse Pull?
I know with the Corvette's there are a fuse to pull to leave the exhaust open all the time. Is the ZL1 the same? and does anyone know what fuse number would leave the exhaust valves open?
Also does the Camaro have the 4 cylinder mode like the Corvette and can it be disable besides using manual mode? Thanks in advance!
2022 Black ZL1
RotoFab CAI, AWE Touring Edition Cat Back Exhaust. 665 Crank hp. est. and 660 Crank ft. lbs. est. Never been Dynoed |
11-04-2021, 06:57 AM | #2 |
Drives: 2019 ZL-1 Join Date: Feb 2009
Yes do a search. NPP fuse pull
2019 ZL-1 Acquired 4/23/21 at 6300 miles. Riverside Blue, A10, PDR. Traded in 2017 2SS with 6M and 32k miles. Continental Extreme Contact Sports. Now has 10,000 miles...
2012 Yukon XL Denali w/ 6.2 AWD |
11-04-2021, 07:03 AM | #3 | |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
11-04-2021, 10:19 AM | #4 |
Drives: '20 ZL1 M6 Join Date: Apr 2017
Fuse pull is #51. For a bit more sound, get rid of the secondary cats. No O2 sensors, so no code. Same great sound, just more of it.
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
11-04-2021, 10:25 AM | #5 |
Drives: 2018 Camaro SS vert Join Date: Oct 2020
I marked the fuse location with a drop of nail polish, this way if I ever want to replace it I don't have to wonder which empty slot it is
11-04-2021, 12:04 PM | #6 |
Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
Look under the fuse block cover for a map of the locations. No AFM on ZL1s so no AFM valves on ZL1s. As mentioned, NPP valves are controlled by fuse 51.
2002 Corvette Z06 - Black - Sold
2013 Camaro SS 1LE - Black - M6 - Sold 2016 Camaro SS - Mosaic Black - A8 - Sold 2017 C7 Stingray - M7 Coupe - Sold 2019 C7 Grand Sport M7 Vert - Sold 2021 Camaro ZL1 - Black - A10 - Sold 2019 Tesla Model 3 2022 CT4-V Blackwing - M6 |
11-04-2021, 01:08 PM | #7 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
11-04-2021, 05:03 PM | #8 |
Drives: 2018 Camaro ZL1 1LE Join Date: Mar 2021
If you have the settings set to the loudest mode with NPP, how much of a difference is it with the fuse pulled?
Looking for more sound before I get an exhaust but also need the NPP for when i take the car out early in the mornings and the family is still asleep. I know in my c6, the fuse pull was a big difference because the valves would not open unless you were on the throttle pretty good. The zl1 seems to stay open more often, but maybe not above a certain speed? |
11-04-2021, 06:54 PM | #9 | |
Drives: 2019 ZL1 Join Date: Mar 2019
Basically in track mode the valves close under cruise at a certain rpm, cant remember off top of my head. So if you pull the fuse, the valves will of course remain open. Just pull it and see if you like the sound, if not, put it back.
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
11-04-2021, 07:45 PM | #10 | |
The problem is even in Track Mode the valves still close and some folks don't like the muted sound you get when you get on the throttle from cruising at 1700 rpm when the valves are close. You get this "hitch" where the exhaust mutes and unmutes so to speak at lower RPMs. When you pull the fuse you will get a more consistent exhaust note and volume/growl at lower RPM. In addition, since the exhaust is not that loud to begin with you really don't get any drone either. You will not get a CEL when you pull the NPP fuse. For cars with AFM, there is also a set of AFM valves that open and close based on whether you are in V4 or V8 mode. Not a fan, anyway, you will get a CEL if you pull the AFM valve fuse. It doesn't help anyway since the exhaust will sound like crap when in V4 mode without the AFM valves doing their thing. This is one of the benefits of the ZL1s and M6 SS Camaros, AFM is not enabled. By the way, I read that you can't even pull the NPP fuse on the new C8s without a CEL. Annoying...
11-04-2021, 08:03 PM | #11 | |
Yea it sounds like for now the fuse pull will be helpful. I just think I need a mild to wild switch like was common in the corvettes. That way I can leave the house in the morning in stealth and not wake up the family, and then simulate a fuse pull for the rest of the day driving. it will be even better with exhaust down the road! |
11-04-2021, 08:09 PM | #12 |
Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
I did the fuse pull on my 2017 and didn’t make that much difference in the sound even when I had the exhaust set it to Track Mode so I put the fuse back in.
ZL1 Coupe, PDR, Exposed carbon fiber hood insert, My Link with Nav, M6 6 speed and Silver Ice Metallic. Mods done: ceramic window tint, GM Accessories Camaro floor mats and Roto-Fab CAI.
11-15-2022, 12:58 PM | #13 |
Drives: '23 LT1 conv, '07 911 Turbo Join Date: Jun 2018
So in terms of the Fuse pull itself... does it just control the sound via valve control or does it also override the other features of the mode settings? I.E. throttle control differences between say S/I and Track or Sport mode. I am thinking that when S/I mode is selected, the throttle definitely has a more dead feel. The reason why I ask is I plan on driving it in the Winter months and when the fuse is pulled, all of the modes "feel" the same, almost like that fuse controls the pedal as well.. but I could just be wrong because of the valves being opened all of the time. Some educated thoughts on this are appreciated.
11-15-2022, 01:20 PM | #14 | |
