Old 02-27-2016, 12:24 AM   #1
GetYouOne
Drives: 2012 2SS/RS
E85 Conversion
I know its been covered in the past just wanted some up to date reviews. Really thinking about switching just wondering what kind of #'s u guys were seeing on ur F/I rides?
My tuner wants to go with a Fore pump and 1K injectors and with the flex fuel kit. What are u guys running with ur setup? Thanks.
GetYouOne is offline   Reply With Quote
Old 02-27-2016, 05:49 AM   #2
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
Squash pump (soon) but the average gain on a boosted vehicle is between 40-50 rwhp.
Trob85 is offline   Reply With Quote
Old 02-27-2016, 08:25 AM   #3
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Doing my conversion right now. Fore dual 450s, fic 1000s and flex fuel sensor. Will be on the dyno in 3 weeks. Wish I had more info for you
ttshovel is offline   Reply With Quote
Old 02-27-2016, 09:46 AM   #4
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10
E85, cam and heads netted me 130whp. I would expect about half of that was E85.
LPE twin fuel, ID-1000's
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 02-27-2016, 11:57 PM   #5
Detoxx03
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Detoxx03's Avatar
Drives: 2008 Corvette
Fore triple kit, DSX flex fuel sensor kit with display, and ID1300s.
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 02-28-2016, 11:40 AM   #6
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
I have a Fore Innovations twin pump flex fuel system going in soon.
ID1000's.
Twin TI Auto F90000274 pumps.
We have good E85 out here even during the winter.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno)
Jeff_SS is offline   Reply With Quote
Old 02-28-2016, 04:39 PM   #7
CamaroRich
CamaroRich's Avatar
Fore triple pump, flex fuel system, ID1300's on twin turbos. No issues so far, other than shortage of E85 in my area.
CamaroRich is offline   Reply With Quote
Old 02-28-2016, 06:47 PM   #8
2010SSRSM6
2010SSRSM6's Avatar
With the squash kit and Bosch 1000cc injectors both a buddy of mine and I saw close to 50rwhp gain over 91. I was 748rw with a maggie, E-85, meth and 12#'s of boost. Motor is getting forged (stock cube) and I'm adding heads and maxing the blower out now. Hoping for close to 800rw.
Old 02-29-2016, 05:52 PM   #9
mj446699
mj446699's Avatar
Drives: 2015 2SS Ashen Gray Metallic
E85
From 91 to E85 I saw close to 140 rwhp. I tried uploading it but it's too large and I can't resize it from the phone. Went from around 550rwhp to 692 rwhp. The biggest change is the timing when going to e85. You can increase boost on E85.
mj446699 is offline   Reply With Quote
Old 02-29-2016, 06:16 PM   #10
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Went from 580whp at 10psi on 93 to 640whp on 8.5psi on e85, awesome stuff and $1.59 a gallon currently
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 02-29-2016, 06:30 PM   #11
GetYouOne
Drives: 2012 2SS/RS
Impressive #'s guys. I'm at 7.5lbs right now 547rwhp I still need to delete my cats and upgrade my crappy FAST injectors. E85 sounds like the way to go. My local station just started selling it too.
Old 02-29-2016, 06:48 PM   #12
fif_gen_powa
Its the way to go on a FI car no doubt. Be prepared for you MPG to take a big dive, only 10mpg city but I don't give a crap it's so cheap anways lol
8.3@164
Old 02-29-2016, 07:41 PM   #13
mj446699
mj446699's Avatar
Yea I think I got around 9 to 10 miles per gallon on it when I first brought it home. But it's worth the extra power
Old 01-15-2017, 02:42 PM   #14
blueranger
Drives: 1970 Ford Bronco
Any source to buy a complete kit with injectors sensors and needed fuel lines?
blueranger is offline   Reply With Quote
