08-23-2017, 05:42 PM | #1 |
Drives: 2017 ZL1 Join Date: Nov 2009
Any suggestions for a quality battery tender
Does anyone have any experience with a battery tender that is safe to use on the ZL1?
08-23-2017, 06:12 PM | #2 |
Wicked ZL1
This is the one I use, works great. I wired it to my battery:
Deltran Battery Tender Power Plus 3 Amp http://www.ebay.com/itm/like/1524090...=ps&dispItem=1
2017 Hyper Blue Metallic ZL1 A10/CF Hood Insert/PDR/NAV MODS: Rotofab CAI/V-MAX CNC Ported Throttle Body/Clear Bra/LED Reverse Light/Rock Guards/Lift Pads/Darkened Tail Lights/Ghost-Tinted LED Side Markers/Darkened 3rd Brake Light
08-23-2017, 06:36 PM | #3 | |
08-23-2017, 06:42 PM | #4 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
Mine came with the battery charger. I have used Diehard and some other company in the past. Battery Tender is good. I think they all are pretty decent. It mainly depends on which one you're more comfortable with.
08-23-2017, 07:12 PM | #5 |
Drives: 2011 Camaro Join Date: Sep 2010
mine came with the camaro battery tender..
2017 Garnet red ZL1 A10 Procharged LME 427 L8T
08-23-2017, 07:46 PM | #6 |
Drives: Lexus, ZL1 1LE, Ducati, Suzuki, Join Date: Jul 2017
I am the same as Flynnzl1.
Deltran battery tender. I have 8 of them lined up along the wall with 25ft extensions from Deltran that run to each vehicle. I have never had a problem with one. I put a wiring harness on each battery that Deltran supplies and then I use their 25 ft extensions with the plug ins on each end and run that to each charging unit. |
08-23-2017, 07:49 PM | #7 |
Wicked ZL1
My ZL1 came with a Camaro battery charger, but I wanted to wire it to the battery so I can unplug easy.
08-23-2017, 08:24 PM | #8 |
Drives: 2017 A10 ZL1 KG Join Date: Oct 2014
So how long should I go before using the charger
08-23-2017, 08:28 PM | #9 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
Just keep this a bit in perspective: You don't need any type of charger at all if your car's gonna sit LESS THAN 2-3 WEEKS.
It's when you store car for longer than three or four weeks, e.g the winter, long vacation that you need a tender. The car shuts down after 10 minutes to sav on the battery for shutting everything down and Going to sleep. Don't get paranoid about not having a charger if your car is driven at least 2-3 times a week. Last summer I did five weeks away, battery connected, and came back and it started fine.
08-23-2017, 08:36 PM | #10 |
Wicked ZL1
Mines out for a month and a week and was completely dead
08-23-2017, 08:43 PM | #11 |
Drives: 2018 zl1,A10,16 GLC300 Join Date: Jul 2017
Ctek
2018 ABM,A10
Kooks 2” headers no cats, NW 103 Tb, Kong ported blower with 2.31 pully, Elite E2x catch can, Cordes under hood expansion tank, Flowmaster axle back, Rotofab dry filter,Mustang Dyno # 647whp/674wtq. |
08-23-2017, 08:55 PM | #12 | |
Drives: Current driver AMC emlin X 5ltr. Join Date: May 2011
08-23-2017, 09:02 PM | #13 |
I have gone on vacation for 3 weeks and come home to a dead car so now I put all my daily drivers on chargers when I go out out town for more than a week and I keep all my toys on chargers all the time and just unplug the one I want to use that day and when I return home it gets plugged in again.
Sometimes some of my toys do not get driven for months though and the electronics in them slowly drains them so I keep them plugged in all the time. For my camaro, I have the harness for the camaro charger on the battery and the battery tender harness also but I have only used the battery tender so far. |
08-24-2017, 07:23 AM | #14 |
Drives: 2017 Camaro ZL1 Join Date: May 2017
I bought the "Camaro" one that GM sells either as an option with the car or as a standalone part. It wasn't cheap, but I figure if it is sold by GM for use with the Camaro then it is properly spec'd for it. TGMPG will save you some money, if you go that route.
2017 Black ZL1 6MT
