12-17-2012, 10:53 PM | #1 |
Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
Reddish/Pink oil leaking around my oil filter and cooler area
Can anyone please ID what this fluid is and where it's likely coming from?
I've got a 2010 LS3. It's been sitting in the garage since mid-Oct and I've started it once. You can see where it's wetted the oil pan and tranny housing. There's also some drips on the small, black cross member. Thanks...
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM |
12-18-2012, 10:09 AM | #2 |
Drives: 2012 Camaro 1SS LS3 Join Date: Jul 2008
It looks like transmission fluid to me. Check the gasket around the pan.
12-18-2012, 11:43 AM | #3 |
Drives: 2012 2LT 45th convertible Join Date: Jul 2010
I'd agree with this, I see a drip on your oil cooler lines so I'd think ther leak wouldn't be the pan gasket but higher, check all cooling lines and fittings
Top Ten Reasons I Procrastinate
1. |
12-18-2012, 03:18 PM | #4 |
I've got the LS3 manual 6 speed, so I didn't think it has a transmission pan. If it is the transmission, then where is the reservoir for the tranny oil? I know it shares the same fluid as the brake, but the brake fluid is clear.
12-18-2012, 03:22 PM | #5 |
Blown Cool Breeze
Drives: 2011 Black on Black 2SS M6 Join Date: Jul 2010
Your manual 6 speed trans has a oil cooler that is built into the radiator.
Check the lines for tightness all the way from the trans to the front,that is what is leaking.
Had a 2010 IBM 2SS M6 Enjoy life.Think of all the women on the Titanic who passed up dessert. |
12-18-2012, 04:52 PM | #6 |
Banned
Drives: 1991 New Yorker, 69 Tbird, ABM2SSRS Join Date: May 2009
Your Transmission is sealed. The access is on the top of the tranny for fluid change(adding). Only the clutch shares the brake fluid reservoir.
12-18-2012, 05:19 PM | #7 |
Drives: CGM 2SS/RS, 1987 & 2014 Silverado Join Date: Oct 2010
Dex-cool?
12-18-2012, 05:52 PM | #8 | |
Where's the tranny fluid access point?
12-19-2012, 01:37 AM | #9 | |
Drives: 2011 Camaro SS/RS - 2004 Silverado Join Date: Mar 2010
Honestly, I think you have a leak around your oil cooler. The cooler is next to the oil filter and it uses coolant from the radiator. Check the cooling lines for leaks and the cooler itself. I believe there is a TSB on a leaking oil cooler anyways.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80 2004 Black Silverado 1500 2WD Regular Cab, Short Bed -5.3 LM7, 4L60E, 3.42, G80 2014 White Caprice PPV -6.0 L77, 6L80E, 2.92, G80 |
12-19-2012, 02:38 AM | #10 | |
12-19-2012, 04:58 AM | #11 |
On a side note, are those magnets meant to capture shavings? Does it work?
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
12-20-2012, 12:05 AM | #12 |
Yes, they are. Don't know yet since I only installed them last year. Will report when I do an oil change next year.
12-22-2012, 08:35 PM | #13 |
Drives: 2010 SS L99 Inferno Orange Join Date: Apr 2012
12-22-2012, 08:37 PM | #14 |
Drives: 2012 45 Anniversary Vert Join Date: Apr 2012
still under warranty? take it to the dealer Ide say.
