05-20-2016, 10:26 AM | #1 |
Drives: CMRO2LS Join Date: Mar 2016
COLD AIR INT for CA Residence
Good day ya'll
I was thinking on getting a CAI or Roto-fab cold air intake but yes its not legal in CA. Is it a good idea if I still get one and just replaced back to stock when smog test comes? Or if not, what are some legal, best Cold air intake for CA residence? |
05-20-2016, 11:39 AM | #2 |
Drives: 2010 IBM 2SS/RS Join Date: Apr 2010
I have the CAI intake. It took me about an hour to swap it out with the stock parts before my smog. It only took about 15 minutes to put it back in after.
I did buy an extra PVC hose (~$12) so that I wouldn't need to redo the heat shrink. all in all, well worth it. |
05-20-2016, 12:45 PM | #3 |
Drives: 2014 Camaro 2SS RS & Ground effects Join Date: Apr 2014
I too will have the same problem as I am moving to Cali. I kept my OEM air box and will be switching it out with the CAI. As did Jimbabwe did I picked up a spare PVC hose for the same reason, but my only cost 9.00 from MaureenM@RodgersChevrolet (they are a sponsor) free shipping as well.
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260 |
05-20-2016, 03:09 PM | #4 |
Drives: "Kara Zor-El" 2017 2SS HBM Join Date: Jul 2014
If you go for an inspection in CA with a CAI, will they automatically fail it? Or will the CAI not be able to pass because of the way it functions?
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!! What? Dangerzoooooone. |
05-20-2016, 04:31 PM | #5 |
Drives: Supercharged 2013 AGM 2SS/RS Join Date: Oct 2013
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports. 1967 Bolero Red 396 SS/RS Convertible |
05-21-2016, 04:35 PM | #6 | |
