Old 06-16-2021, 01:11 PM   #1
Blownfogger540
Blownfogger540's Avatar
Drives: 2013 ZL1 416
Shifting at higher rpm grinds everytime ????
like the title says its a piss off trans is new gm tr6060 lsa model and is in my 2014 zl1
wont go in till rpms drop is this a tuning problem or what is preventing it from going in to gear
Blownfogger540 is offline   Reply With Quote
Old 06-16-2021, 03:37 PM   #2
fz4k98
Drives: 2013 1ss
Ive had similar issues and have found a couple things that contributed. Did you install it or have it done? Is it a new clutch?
I found that proper spline greasing helps the clutch slide on release.
Hydraulic issue on the clutch master cylinder being too weak for the twin disk
Hydraulic issue where the clutch fluid was getting too hot in the line by the header.
Warped clutch would not slide away fromthe flywheel to allow release.
My understanding on most clutch systems is there is increased pressure plate force based on inertia. Higher speed would create higher clamping force to overcome when pressing in the clutch.
fz4k98 is offline   Reply With Quote
Old 06-16-2021, 04:06 PM   #3
Blownfogger540
its a stock motor stock used clutch new slave new trans car has 22k on it
clutch feels fine no chatter ,but the tick braided lines are abit close to the exhaust
Old 06-16-2021, 07:17 PM   #4
fz4k98
Drives: 2013 1ss
i forgot to mention that Ichanged out the GM transmission fluid to Amsoil which helped on cold shifting. By cold shifting I mean anything below 70 degrees ambient.
I had the trans upgraded and the shifting was terrible prior to fully warmed up. the fluid helped a lot.
Old 06-17-2021, 07:51 AM   #5
Stingr69
'69 Owned Since '79
Stingr69's Avatar
How does the fluid look? If it is dark, you should replace with fresh fluid. Search "Ranger Protocol".
A separate clutch fluid reservoir was a help if you do not already have one.
Apologies in advance if you already know about these.
Old 06-17-2021, 09:32 AM   #6
Blownfogger540
fluids are all new
Old 06-17-2021, 09:19 PM   #7
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
1-2 grind is kinda common in the 6060 my car did it also. you can change to a upgraded synchro. it's a stang bot still a 6060
lemontwist is offline   Reply With Quote
Old 06-17-2021, 09:36 PM   #8
Blownfogger540
good grief buy a new trans and cant even use it POS
