02-18-2021, 10:26 PM | #1 |
Drives: 2013 ss2 vert l99 Join Date: Apr 2017
How far have you pushed the stock ls3 sleeves?
I rebuilt my engine 6 months ago, what started as removing a foreign object in the intake, turned into a cam swap.. and while I was in there I might as well gap the rings... and seeing as I'm gapping the rings I might as well do forged pistons and rods and new bearings..
Well im kicking myself for not sleeving the block (because I'm cheap AF).. so my question is this " how far have you sustainably pushed your stock sleeves (sbe or forged).. I figured 850 wheel was my cutoff but I'm hoping 400 of you tell me 1000+ hp lol. |
02-19-2021, 06:24 AM | #2 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Did you replace your crank too?
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
02-19-2021, 07:32 AM | #3 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Mine cracked at 420 whp...
02-19-2021, 07:55 AM | #4 | |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
I see most builders regularly rate a forged ls3 with stock sleeves to 1100 with arp stuff. 1000 with the stock crank is not uncommon. I know 3 guys locally with stock sleeves making from 830-1150whp, but I'm no expert on the topic.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
02-19-2021, 10:48 AM | #5 |
Drives: 2015 Camaro SS commemorative Join Date: May 2015
sleeves are a con game in the LS world. The 4 bolt head fails long before anything else. I am mobbing an LS3 forged with cheap callie stuff, I make 1200 wheel and run 5's ion the 1/8th mile . Its all about maintenance , spot on tunes and good fuel.
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
02-19-2021, 11:40 AM | #6 |
Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
^^^ This!
1067 on sbe and still trucking. E-85, good tune, and crossed fingers. L O L
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile |
02-19-2021, 05:13 PM | #7 |
Nah, stock crank.. it was a budget build and I know the stock crank can handle more than I was going to throw at it..
I cracked a sleeve at 600hp :-(.. had no idea it was even cracked lol. Glad to hear dudes are hitting 4 digits.. might have to push it then :-) |
02-19-2021, 05:15 PM | #8 |
02-19-2021, 06:20 PM | #9 | |
1000whp sbe. https://youtu.be/Fn84x9YToh0
02-19-2021, 10:14 PM | #10 | |
02-20-2021, 07:59 AM | #11 | |
02-20-2021, 12:55 PM | #12 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
I prefer the term "voluptuous". LOL!
02-20-2021, 10:09 PM | #13 |
2010 transformer
Drives: 2010 ss camaro Join Date: Nov 2014
I did 806 on a sbe but we had a lifter fail. And after all the failures I saw started to really grow at 850 rwhp. So we already had 6 bolt heads i went to a Thompson dart 427 and not much difference in price
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
02-21-2021, 09:02 AM | #14 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
17 lbs.
