01-09-2020, 08:56 PM | #1 |
Drives: G8 GT Join Date: Jan 2017
NA Stroker Power Results
I am still working out some details for an upcoming NA stroker build, and I was hoping for some feedback from those with similar setups. While my setup will be a little smaller than what most of you would have since I am starting with a LS2 block (final hone at 4.005" => 403ci).
General Build Info: 12:1 SCR E85 6L80E w/3200-3400 Stall Here is where I am torn and hoping someone can speak to my concerns... How much do you think factory 821 heads and a ported LS3 intake manifold will choke the setup? Anyone willing to share their power results and setup details? Thanks in advance! |
01-10-2020, 04:43 AM | #2 |
Drives: 11 camaro Join Date: Mar 2017
Running cnc 821 heads and stock ls3 manifold on a 416 and f1a. Runs 10 flat in the quarter, so not a huge restriction.
2011 1SS/ Thompson mtrsprts 416,Katech rotate assembly and cnc ls3 heads. Ferrera st. valves,BTR 685 Spr. F1A Procharger,3.70 pulley on 12 rib.Holley aux fuel pump,ZL1 fp and fpcm,dual alky control,Vmax TB,DSX E-85 sensor, fic1300 inj.Lsxperts custom cam,melling OP,mishimoto dual pass HX, ARH 2" headers, MD 4l80e, FTI 3200 stall,3:73 zl1 cradle, BC coil overs ,pfadt sway bars, EBC brakes and slotted rotors: 843rwhp tuned by LSXPERTS
01-10-2020, 05:00 AM | #3 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
What is your cam choice? The 821 heads flow pretty good for factory heads. The ls3 intake manifold is ok as well. It is all better than the ls2 stuff. But it all depends, what are the goals for the engine? Max effort? Budget build? Street car? Drag?
More to come. Last edited by Black_SS10; 01-10-2020 at 05:42 AM. |
01-10-2020, 08:38 AM | #4 |
Drives: 2013 SS Join Date: May 2013
Depending how your budget is, I strongly suggest porting your 821s and can net you 35whp+.
01-10-2020, 10:37 AM | #5 | |||
This will be a street car with little-to-no track use. It started out as just a budget build with parts I had laying around from other builds... but now I am considering ported or aftermarket casting heads. Just hoping to receive some feedback from other that have been down that road. Quote:
The ported heads are definitely tempting, but for not much more, I could buy aftermarket ported castings then sell the stock heads for practically a wash. |
01-10-2020, 12:36 PM | #6 |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
Ported LS3 heads are already "a bottleneck" for a stroker engine. I am running ported LS9 heads (similar flow) and a ported LS3 intake on my 416, I would probably gain another 20 from the Fast 102 intake. I chose to use the ported LS3 intake for torque under the curve and throttle response though.
On a 402, the factory heads will work, but I suggest sending them out for porting at the minimum. We can port them for $499 https://store.katechengines.com/cnc-...pair-p599.aspx If you're going for torque, stay with the LS3 intake manifold. If you're going for peak power, use the Fast 102 intake with the medium length runners. |
01-10-2020, 09:36 PM | #7 | |
Do you have a dyno graph to share? |
