Old 11-05-2022, 04:04 PM   #1
lincoln361
lincoln361's Avatar
Drives: 2011 Camaro SS/RS
Smile Rotofab Resevoir configuration
Does anybody know the size and which "AN" fitting they used, and what size braided hose yall are using. I circled the part of the resevoir that I want to swap. Thanks in advance
SLP TVS 2300- 1 7/8 LG Headers- RDS NX Plate- 75 Shot- No Cats- SLP Loudmouth 2- NW102- 3.8 Pulley- OD Cog drive-12lbs boost-FIC 80# injectors-ZL1 Fuel Pump- RotoFab CAI- Apex CAI Scoop- Pat G Tune- Weld RTS drag pack- BMR Trailing Arms- BMR 1'' Drop Springs-BMR Lower Control Arms- BMR Toe Rods- BMR Rear Cradle Bushings- BMR Upper Control Arm Bushings- BMR Extreme Anti- Rollbar- Hotchkis Subframe Brace- Prosport Evo Boost & F/A Ratio
lincoln361 is offline   Reply With Quote
