Old 10-19-2015, 03:15 PM   #1
Black Knight
Black Knight's Avatar
Drives: Supercharged LLT
Power steering resivor over filling wit low fluid???
Hello noticed a wine while turning and checked to see power steering resivor , marked a lil low but not empty filled up to the middle between min and max , turn the a couple dozen times to take air out of system . Still whining like crazy , went for a spin around the block came back and now it's foaming out the top, I didt over fill system at all so what's the problem is it my ps pump? This happen to any body ? Any help appreciated thanks
CLICK IMG FOR BUIlD THREAD
Black Knight is offline   Reply With Quote
Old 10-19-2015, 05:37 PM   #2
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2010 Camaro 2SS A6
There's still air trapped in the system. Did you do the couple dozen turns with the cap off? That's the way to do it.
Rock-It Man is offline   Reply With Quote
Old 10-19-2015, 06:06 PM   #3
Black Knight
Yes cap was off when parked doing the turns . I put cap on and drove it a block when it started over filling
Old 10-19-2015, 06:10 PM   #4
Black Knight
I've swapped hoses before and took the air out of the system before but have never had such a issue . That's why I started to think it was the PS pump . Has any body ever used this http://m.oreillyauto.com/mt/www.orei...0678&ppt=C0067
It's a universal airvac
Old 10-19-2015, 06:14 PM   #5
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
It would be very unusual for your PS to have that much air from being slightly low. There was a TSB for PS whine some time ago. The fix was to replace the PS fluid with the new Dexos transmission fluid. I suggest you swap the fluid to cure the whine.
Old 10-19-2015, 06:41 PM   #6
Black Knight
Didt know you could put transmission oil in the power steering pump . What does TSB stand for ?
Edit found it technical service bulltin
Old 10-19-2015, 06:45 PM   #7
JusticePete
Technical Service Bulletin
You want to use this type Mobil1 Synthetic ATF Dexron/Mercon Automatic Transmission Fluid
Old 10-19-2015, 07:19 PM   #8
Black Knight
Thanks Pete I'll look for that . Since it's not a recall I'm guessing if I would take it in I would Get charged huh
Old 10-19-2015, 07:49 PM   #9
JusticePete
They do have a good vacuum system to change the fluid and purge any air. Be sure you specify you want synthetic per the TSB.
Old 10-19-2015, 07:52 PM   #10
Black Knight
10 -4 thanks Pete
