#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Dragstrip and Launching Discussion
AWE Tuning
Old 05-05-2017, 03:33 PM   #1
GreaseMonkey83
GreaseMonkey83's Avatar
Drives: 2016 Camaro
Can launch control be adjusted in HPTuners?
Anyone know if this is possible? I haven't hooked the tuner to my car yet so I'm not sure if there is a table in there for the launch control or not. Sure would be nice if we could adjust the RPM limit.
If not, is there anyone that makes an adjustable 2-step for these cars? Maybe the vettes have something we could use?
2016 Garnet Red 2SS M6 MRC NPP and Sunroof
100% Stock - 12.10 @ 115.6mph - 3620 lbs lookin' at it
GreaseMonkey83 is offline   Reply With Quote
Old 05-05-2017, 09:04 PM   #2
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
I have the same question. From what I can see in HP tuners in my tune file, there are no adjustments in the ECM file to adjust launch control based on looking at the descriptions.
Under the idle section, there is a launch assist idle rpm, but the description says it is for manual transmissions. I have an A8 and the table is zeroed out.
So I'm not sure if maybe this is control by the TCM or another module? or maybe there are no other tables and maybe, in an automatic, it is controlled by brake torque management? And then maybe launch control uses the same wheel slip algorithm as normal traction control does?
I will change raise the brake torque management torque by 20% and report back. There is also a setting, that is enabled stock, that says if enabled, brake torque management can be disabled by traction control events. So I'm not sure if this means, when you put it into competitive mode and disable traction control, that its using something special when you do launch assist/control.
I feel like if we could understand this we could go a long way to getting better launches. I'm surprised how so many people say they don't use launch control at the track, and when they do they go slower? I would like to tune the TCS for a little more spin to see if it would help, anyone else ever experiment with drag radials and traction/launch control?
cmitchell17 is offline   Reply With Quote
Old 05-05-2017, 09:41 PM   #3
GreaseMonkey83
Drives: 2016 Camaro
I have a stick shift car, ill buy the credits and hook the tuner up tomorrow and see what mine looks like. I didn't use launch control at first but after getting coached up by a fellow forum member I started using it properly. My 60's got a lot better and more consistent. I had a 1.88 60 the other night on stock runflats using launch control but like i said, mine is a M6 car. Cant speak for the autos.
Old 05-06-2017, 05:37 AM   #4
Fraxum
Fraxum's Avatar
Drives: a M6 LT1 ordered From Becky!!!
You sound like you spend alot of time at the track.
I gave up on stock and was only able to get to 1.93s on the runflats without LC. When you say using LC properly, do you mean not just dumping the clutch?
I did read somewhere that LC is not tunable, but you can't beleive everything on the Internet.
Old 05-07-2017, 02:37 AM   #5
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
What is your launch method? Lol. I'd love to hit a 1.8 on stock rubber
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 05-07-2017, 08:49 AM   #6
GreaseMonkey83
Drives: 2016 Camaro
slip the clutch using launch control, don't dump it. Stage as shallow as possible. Try to be the first in the lanes to run after the slick tire classes or after the track is prepped. 26-27 psi in the rears. about a 3 sec burnout in 2nd to get heat in the tires.
Old 05-14-2017, 10:53 PM   #7
Racereadyfab
Drives: 2017 Camaro 2SS
Did you find out if LC is adjustable in the tune? I'm going to try using it my 60' sucks but the tracks been not so great the two times I went
2017 Camaro 2SS M6 100% stock at the moment
1.839 60' 12.113@114.95MPH 6/9/17
12.267@115MPH 5/17/17
12.374@116.83MPH 5/10/17
Racereadyfab is offline   Reply With Quote
Old 05-15-2017, 12:04 AM   #8
TJay74
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC
LC is not adjustable in the calibration file that HPT/EFilive has access to. When Chris White added LC to his car several years ago I followed along on the process. I think he had a 2009 Vette and LC had just came out on the 2010 Vette. Since he programmed for GM and knows the ins/outs of their programming he added it to his car, I remember him saying the programming change was in the BCM in order to get it added.
He goes by GTPrix on this board and any other board on the interwebs. Shoot him a message and ask him.
TJay74 is offline   Reply With Quote
Old 05-15-2017, 12:08 AM   #9
TJay74
Here is the page from the C6 Vette forum where Chris talks about adding it.
https://www.corvetteforum.com/forums...r-2009-c6.html
Old 05-15-2017, 08:31 AM   #10
GreaseMonkey83
Drives: 2016 Camaro
Correct, the launch control settings are in the BCM and are not editable.
I did however find a 2 step from LPE.
http://www.lingenfelter.com/PRI2014s...014%20v1.0.pdf
That should do the trick.
