JUICEDMOTORSPORTS
Old 07-06-2010, 09:01 PM   #1
NicksVSix
NicksVSix's Avatar
Drives: 2014 2LT Red Rock Metallic
Resolved : Warning indicator: A/C off due to high engine temp
Hey guys,
A few days ago I posted the above problem, but have since had it fixed at my dealership.
The problem was with the engine coolant temperature sensor. Just needed to be replaced.
If anyone runs into this problem (you can view it here: http://www.camaro5.com/forums/showthread.php?t=93094)
this is the most likely cause. Rest easy, your engine is probably *not* overheating.
Cheers,
Nick
NicksVSix is offline   Reply With Quote
Old 07-09-2010, 10:02 PM   #2
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
Cool, glad to hear they found the culprit!
HeavyD is offline   Reply With Quote
Old 11-01-2010, 05:43 AM   #3
NEGXXIS
NEGXXIS's Avatar
Drives: 2016 Camaro SS A8
I have had this happen twice in 2 weeks....GRRRRRRRR !!!!!!!!!!!
Ordering yet another sensor today.
2016 Camaro SS – factory Summit White - Avery Satin Pearl Nero Wrap with Carbon fiber and gloss black accents – Anderson Carbon Hood and Rear Spoiler – Ikon front spoiler – MP Concepts Side Rockers - ZL1 Addons Diffuser - Oracle LED smoked side markers – GM Dark Tail and third lights - Phastek 1.5” Lowering Springs - MRR 228 Wheels 20x10 and 20x11
2004 Chevy 2500HD Diesel - 601 rwhp / 1089 rwtq
SOLD - 2010 Camaro SS - Featured in GM High Tech Performance and Camaro Now Magazines - http://www.superchevy.com/features/g...of-perfection/
NEGXXIS is offline   Reply With Quote
Old 02-12-2014, 07:06 PM   #4
RickJack11
RickJack11's Avatar
Drives: 2011 Camaro
How much does the part cost? Mines is doing the same
RickJack11 is offline   Reply With Quote
Old 02-19-2015, 08:26 PM   #5
Freyguy08
Freyguy08's Avatar
Drives: 2012 Camaro 1SS RS
+ 1
Comin' in hot!
Freyguy08 is offline   Reply With Quote
Old 03-02-2015, 08:06 AM   #6
Brett64D
Brett64D's Avatar
Drives: 2010 2SS/RS A6 LS3
Where is the temp sensor located? I cannot find it!
Whipple 2.9L Supercharger, Stage 2 CNC ported heads, Stage 3 Blower cam, ID850 injectors, 3-bolt cam sprocket, Lonnie's double fuel pump system, DOD/AFM Delete kit, ARP head & crank bolts, Trans cooler, Circle D Multi-Disc Torque Converter 3600 Stall, Lakewood sub-frame connectors, BMR Rear Differential Cradle bushings, BMR front and rear sway bars, BMR lower control arms, Lakewood trailing arms, Lakewood adjustable Toe links, One-piece 3.5" Aluminum Driveshaft, 1400 HP Axles. Demon Eye Halos, RapidFire Brake light LEDs, Maas Monaco rims (Custom painted for color match), Heritage Grill.
Brett64D is offline   Reply With Quote
Old 03-02-2015, 09:50 AM   #7
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2010 Camaro 2SS A6
On the V6 it's threaded into the left side of the block, aft of the oil filter canister.
It's well below the coolant high water mark, so you have to drain the coolant before replacing.
Rock-It Man is online now   Reply With Quote
Old 03-02-2015, 10:41 AM   #8
Brett64D
Brett64D's Avatar
and on the LS3?
Old 03-03-2015, 12:36 PM   #9
Rock-It Man
and on the LS3?
On the LS3 and L99 it's in the left head, just forward of the exhaust manifold.
Installation torque is 15 lb.ft., BTW.
Old 11-17-2016, 10:53 AM   #10
Brett64D
Brett64D's Avatar
I forgot to update this thread. What we found was the wires to the temp sensor were very brittle like they had been overheated. Replace and insulated the wires and have not had this issue again.
Over 230 Satisfied 2010 Camaro Customers! Paddock Chevrolet has 40 in stock NOW camarojoe Dealer Camaros for Sale 2 05-24-2010 05:58 PM
GM's OLM & synthetic oils. duder4thgen Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 03-24-2010 11:37 AM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
GM moves closer to HCCI engine production Scotsman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-16-2008 06:16 PM
Axial Vector Engine Mr. Wyndham General Automotive + Other Cars Discussion 6 06-20-2007 04:00 PM
