09-28-2018, 03:38 PM | #1 |
Drives: 2014 C7 Join Date: Oct 2013
Vararam Power Wedge Dyno Run !!
09-28-2018, 03:43 PM | #2 |
09-28-2018, 09:03 PM | #3 |
So 11.5hp and nearly 21tq?
If true, that's some of the cheapest power you can buy for these cars. VR, can this be used with my Vararam SS intake (2010 L99) without modification?
09-29-2018, 07:46 AM | #4 |
old school chevy rodder
Basically adjusts the angle of the TB to a different angle to decrease bottle neck angle of TB with its down turn off manifold and also further disperse air to atomize air/ fuel.....
Why the numbers on the chart are lower below 2300? Could just be a stumble on the run up between runs..... But I know a guy whos ran one from the get go. He likes it.
09-29-2018, 07:55 AM | #5 |
Drives: 2015 1LE Join Date: Oct 2015
There has been testing of this and it does not make this kind of power, its all advertisement. The video shows a yellow camaro during a dyno run, big deal, what does that prove.
09-29-2018, 09:26 AM | #6 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
i felt a difference when i installed the wedge. i've used it on both the OTR and DRX intakes
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
09-29-2018, 11:05 AM | #7 | |
VR tech |
09-29-2018, 11:23 AM | #8 | |
Data logs from Corvettes to Camaros show a MAP Pressure improvement and a flow increase in the MAF. The flow bench shows an improvement all the way through the cylinder head. There is a min power gain that is guaranteed. All cars and combinations will very. This car was a stock automatic. We have never had to take a Wedge back because it did not work. The best part is ,....It's cheap HP and Torque. After all, how can someone ever expect to make full/max Power when their Throttle body blade is blocking the floor of their manifold? VR tech |
10-01-2018, 12:44 PM | #9 |
More independent test results for the PowerWedge
10-01-2018, 01:21 PM | #10 |
Drives: cars Join Date: May 2011
So independent 4ft lbs, which is dyno error, vs 21ft lbs which is b.s.
10-01-2018, 02:31 PM | #11 | |
You will find 9-12ft lbs at peak Torque and a fatter HP curve giving 8-10 hp leading to a peak power gain at max RPM of 5-8HP. Most have Zero dial in time . If you drive a few miles on the dyno and give the ECM time to learn you will make more power. Increases in MAF flow and manifold pressure don't come from BS parts. VR tech |
10-01-2018, 02:33 PM | #12 | |
Seems like average gains are 4-6 whp and 8-12 wtq. Worth while mod in my mind. Everything adds up in the end!
2010 2SS/RS
10-01-2018, 03:04 PM | #13 |
People like this say what we do bolt ons is impossible as well lol Glad I am moving on to cam only I hope it will make them feel better.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85 Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE 10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake Best 1/8 6.80@105.75 Best MPH 134.82 |
10-01-2018, 08:28 PM | #14 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Interesting...
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
