07-23-2013, 04:40 PM | #1 |
ROCK
Drives: 2013 ZL-1 TRIPLE BLACK VERT Join Date: Oct 2012
17" vs 20" DRAG RADIALS
I am debating between 17" and 20" drag radials for my 2013 A6 ZL1. I am looking for info from anyone who has used either size.
PRO VS CONS THANKS
WHEN ONE AMERICAN IS NOT WORTHY TO BE FOUND...THEN WE AS AMERICANS HAVE LOST. POW/MIA YOU ARE NOT FORGOTTEN
07-24-2013, 07:34 AM | #2 |
Drives: 2017 ZL1 A10 Join Date: Sep 2009
Just put a set of Mickey Thompson ET Street II's on the stock 20 inch wheel, and am loving it. I cannot get these tires to spin! (On the streets) Haven't been to the track yet. The only downside is, with a wear rating of "0", they're not gonna last long. Oh, and mine are turning on the rim. Not much, only an inch or so after some spirited driving. But something that will have to be addressed at the track, I fear.
2017 ZL1
A10 Redhot with stripe |
07-24-2013, 03:46 PM | #3 | |
ROCK
07-24-2013, 07:46 PM | #4 |
I know they're not suppose to. They are definitely slipping though.
2017 ZL1
07-24-2013, 08:07 PM | #5 |
Drives: 2004 SRT10 Join Date: Jul 2013
Tire pressure to low? Only thing I could see to cause the rim to slip on the tire. The tire pressure is what holds the tire to the wheel unless you have too much wheel for the tire.
2011 135i (sold)
2004 SRT 10 Viper (sold) 2006 Z06 (sold) 1970 Mach 1 (sold) 2007 GT500 (sold) +20 others |
07-24-2013, 08:13 PM | #6 |
5.0 lol...
Drives: 2010 Camaro 2SS M6 Join Date: Aug 2012
Can the ZL1 even fit a 17" rim stock? The SS can't, I don't think the ZL1 would be any different...
2010 2SS M6 SWG built turbo car
2000 Z28 A4 Custom tuned by a Skinny White Guy |
07-24-2013, 09:10 PM | #7 | |
Told you these tires were sticky.
2017 ZL1
07-24-2013, 10:18 PM | #8 |
Drives: 67RS Camaro ,Black 2013 ZL1 Join Date: Jun 2010
07-24-2013, 10:21 PM | #9 |
Drives: 2010 Camaro Join Date: Feb 2010
A 17" bogart bolts right on. Didn't even to tie back the E brake cable.
07-24-2013, 10:36 PM | #10 | ||
Seeking 9s on M6...
Drives: 2012 2SS/RS LS3 aka "BlackWidow" Join Date: May 2012
I'm not a tire expert, but this is what I've picked up along the way...
07-25-2013, 12:45 AM | #11 |
Drives: 2013 ZL1 Join Date: Oct 2012
i have 18s up for dirt cheap
C6Z06 400ci, twin gen 2 promod 88's,th400, Alky car
07-26-2013, 12:33 PM | #12 |
ROCK
17" WOULD BE DRAG RACING ONLY. BOTH BOGARTS AND WELD MAKE WHEELS THAT WILL FIT . MT AND HOOSIERS HAVE 325/45/17 DRAG RADIALS
07-26-2013, 03:37 PM | #13 |
Drives: ZL1 Join Date: Oct 2012
I am running my Mickey ET Radials at 18psi have not had the spin on the rim problem.
07-26-2013, 05:54 PM | #14 | |
They did use soap while installing the tires on the rim. That's probably the problem. I think after a few heat cycles it will fix itself. I'll give it a week or so, then post the results.
2017 ZL1
